jvander67 ('90 Festiva won't start... suggestions?)
I drive a 1990 Ford Festiva auto transmission...It has run great for years...today i turned it off and it wouldn't start. It cranks over well...we used a timing light and it is getting spark. Tank is full of gas...Are there any other Festiva owners on here that might have a suggestion?
Can you hear the fuel pump kicking on? Have somebody go put their ear up to the tank and then turn the ignition on. You should hear it kick on to prime it.
Also have you tried a little ether/starting fluid to see if it would try and fire? |
jvander67
