Kadet E GT EV Conversion
3 Attachment(s)
Hy all
i just bought this "beast" 960 kg / 115hp / and an echonomical 20l/100km hope to become an nice ev :thumbup: planned components drive: motor warp 9" paul's 500A controller 10 GEL forklift batteries chargers DIY charger solar pannels small 2 kw generator (petrol) for extended range or fast charge Attachment 4525Attachment 4526Attachment 4527 |
Hey look its already a EV it has a battery charger hooked to it... :D
Kidding. Keep the info coming... Dave |
update
the car is at the boday shop for repairs in the meantime we have ordered the comtroller (thanks Paul) and the motor (thanks Netgain) we have started the gas peddal conversion (pictures will follow) gas pedal is based on clasic design with cable and an 5k variator for batteries we plan to use 10 calcium batteries (around 100 EURO) SLA 75 wich will give is around 100km authonomy found compatible chargers for 144v list atached (can be used as guide for our charger) different batteries and chargers brochure atached including cheap calclium batteries Hotfile.com: One click file hosting found digital scope and pannelmetters for replacing old metters on car those fit perfect replacing old ones atached also here / maybe are usefull for others Hotfile.com: One click file hosting secondary solar charger .... secondary gas generator .... to be checked for performance |
8 Attachment(s)
progress
DONE signal lamps are now leds original lamp was using 25w lamps led lamps use 7 12v leds 0.6W all (0.047A measured for the 7 leds) price 10USD / Lamp TODO building signaling circiut because old relay will not work due to low current UPDATE i have found and ordered 100x150 cm of fotovoltaic cells for roof 200 USD for all will see the test for performance from diagram each cell is 36v/7A rear lapmps conversion will follow shortly Attachment 4726Attachment 4727Attachment 4728Attachment 4729 Attachment 4730Attachment 4731Attachment 4732Attachment 4733 |
8 Attachment(s)
work started to rear lights
but unforunately stoped for 1 week i need more leds :( for now only rear light is working calculated cost 30 USD/lamp block tests rear light 100 mA (0.1A) original light bulb 21W rear signal light 100 mA (0.1A) original light bulb 21W rear brake/position 100mA+50mA (150ma) original light bulb 21W/5W Attachment 4739Attachment 4740Attachment 4741Attachment 4742 Attachment 4743Attachment 4744Attachment 4745Attachment 4746 |
3 Attachment(s)
new signal relay is ready
original diagram was published on tehniq i have modified it for our needs biggest current is 50mA x4 when all 4 lamps are lit so max current must be arroud 200 mA i took 1A to be shure so for command i used an BD237 Q1=Q2=BC171 Q3=Q4=Q5=BD237 and also i have atached my simplified diagram price for simplified diagram 3USD Attachment 4754Attachment 4755Attachment 4756 |
2 Attachment(s)
solar pannel has arrived
36v 7A on load (252W real/250W rated) so i will need an dc2dc conv for 144v dimendions 1000x1500x5 mm price 200USD will replace car roof and blend into the car update i will change the 36v 7A on load (252W real/250W rated) dimendions 1000x1500x5 mm with 36v 5A on load (180W real/180W rated) dimendions 900x1100x5 mm price 180USD because the big one cant fit on the top of the car and add an new one on the hood later Attachment 4768Attachment 4769 |
1 Attachment(s)
update
buyed 4 rims with new tires for the car 195x50x15" 12kg each new tire+rim searching for an new carbon hood to be lighter than existing one searching for new bumpers Attachment 4774 |
Wow, you don't stand in one place long do you?:thumbup: Keep 'em comin' jerpelea, you be Mr. Dynamo! :D Eric |
1 Attachment(s)
info update
car is at car repair and is coming along nice now being disasembled and cleaned for rust after some searches for electrical part we need 1.dc-dc converter 36-144v (500W) 2.ac-dc converter for 110/128v generator (5Kw) so we need to buy/build them i have found an drawing of what i want it to look (bumpers and dors ) Attachment 4776 |
I'm just waiting on the mosfets! I can't wait to read more progress from you!!! Ya!
update
just got the response from battery seller we will use 10 FIAMM 12SLA75 (Calcium Batteryes) for main pack Nomina Voltage = 12 V Nominal Capacity (10 Hours) = 75 A Shortcut Current = 3000 A Internal Resistance = 4Mohm Dimensions LxWxH =360x164x228 mm Weight = 29kg total weight 290Kg for main battery pack we will use 1 FIAMM 12SLA50 (Calcium Batteryes) for 12V DC (to be checked if is better to use dc-dc converter 120-12V ) (how it influences the overal performance adding 21kg for 1 battery or use main power also for electronix) Nomina Voltage = 12 V Nominal Capacity (10 Hours) = 50 A Shortcut Current = 2030 A Internal Resistance = 6Mohm Dimensions LxWxH =288x173x202 mm Weight = 21kg |
7 Attachment(s)
Update
the car has new rims on it and also work on the body has started there is no more rust next week i hope to get all leds to finish the lamps Attachment 4801Attachment 4802Attachment 4803Attachment 4804 Attachment 4805Attachment 4806Attachment 4807 |
Awesome work! That's what I call a work space. Man! Not fair! That car is going to be perfect for a conversion.
update on electronics design to lighten the car and lower the costs !
solar pannels are (180W on top of the car and 60W on the hood installed power) due to limited car space for solar power, total is 240W/h so best charge will be 240wx8h=1920W / day to benefit from all this energy we need to charge both packs 144v and 12v and loose lot of power on voltage conversion pannels have 36v so an down conversion to 12v and an up conversion to 144v the design will be complex and we thought for something else an single pack for propulsion and electronics so car will use single battery pack for propulsion and electronix so the new plan an computer power supply can convert 90-240v ac to 12V/20-50A dc depending on model so we can use an computer power supply if we modify it for dc imput (remove primary ac-dc block) and create better cooling removing the case/fan and create an new case from big aluminium radiators Also computer power supply has an conversion rate of 85-92% wich means that is better than any home built power converter Also 30A is enough for powering the lights 70W = 2x35W HID Lamps for headlights 5W = all signal and position lights 5W = all internal lights 20W = controler board 20W = radio device 90W = Heater (very important) 40W = computer and gps (Asus Eeepc 7" converted as dash computer) total for now 160W so less than an 400W power supply the second improvement usind only one battery pack we need only one converter from 36v dc solar pack to 144v dc (solar pannel has 240W so an commercial 12v dc to 110/220 ac 300W is enough) this type of converter is used to power house electronix from an car battery in car and we need to add an ad/dc converter on the output and charge the car battery also using this the variable 24-36v loar pannel output is converted to stable 12v and from there to 144 from this convertor so 2 power issues are solved in theory i will come with design updates and pictures soon !! |
6 Attachment(s)
update
to test my power theory i have ordered an 500W 12 to 110v convertor for solar pnel 500W 110v to 12v convertor for electronix also LEDS are here and first backlight is ready clean and nice 150mA with all lights lit i need some sleep :thumbup: Attachment 4809Attachment 4810Attachment 4811 Attachment 4812Attachment 4813Attachment 4814 |
both backlights are ready
tomorrow some pictures and maybe if i have time an move with all backlight functions rear light 1 piece 12 LED - rear light 12 LED - rear light signal 16 LED - position and brake 12 Diodes 1N4007 to reduce voltage on position circuit in series with LED to dim LEDS on position lights (0.6vx12 diodes=7.2v) also 1 test board for rear lights price 25 USD/light block total price 50 USD |
Nice job on the tail lights. :thumbup:
8 Attachment(s)
update
i got front lights :d old front lights H4 55W+60W i have measured the current for 1 bulb is short light (60W powered)4A long light (60W+55W powered)=4A+3A total 7A (84W) so the indication on the bulb is not right :D but is too much for an electrical powered vehicle i got an set of BMW HID lights (pictures atached) with rated power 35W so i will need to find H4 hid bulbs and i am ready measured current for 1 lamp 2.2 A (39W) this hid is used for both short and long lights so total used power per side is 39W also rear ligts are ready and current is measured for 1 tail light 0.03A (0.36W) = position 0.17A (2.04W) = brake 0.13A (1.56A) = rear light 0.13A (1.56A) = reverse those values are final llights are tewaked for optimum contrast Attachment 4820Attachment 4821Attachment 4822 Attachment 4823Attachment 4824Attachment 4825 Attachment 4826Attachment 4845 |
5 Attachment(s)
finaly
power supply 100-240v/12V-34A(2x17) 85% randament has arrived silverston SS430GB pc power supply it can handle input 110v-240v range (144v is in range) 7A top this pc power supply is rated 82+ at 110V from my test i have 85% conversion at 144V for 100W drain i get 85W output features output dual 12v 17A rails from independent outputs 17A for elecronics 17A for lights i think that is enough for all i have maximum power on 12v is 360W power supply is protected to overcurrent shortcut and has thermal shutdown for dc imput i need ti remove first AC-DC block and the converteri s ready i need to make new sealed case 150x100x100mm from aluminium blocks wich is enough to remove the fan and cool the power supply mods i have removed all useless dc lines 3.3V, -12V and 5V i have added an swich to power the supply (soft start) pictures of modded power supply are atached last picture is an closeup for the ac-dc block you need to remove it and plug the battery in place of his marked "+"."-" terminals !BEWARE OF POLARITY Attachment 4846Attachment 4847Attachment 4848 Attachment 4849Attachment 4850 |
3 Attachment(s)
also 12v-220v inverter (500W) has arrived
it will be used for solar pannel chardger (240W/h top) pictures atached i will need to remove some cooper from transformers (2x 12/220v - yellow ones) to get 144v but now is working on 220v for now i have plugged 300W halogen lamp and convertor is working nice i have top 240W from solar pannels so is enough for me for test the converter is plugger afer the modified computer power supply and i have tested both and are working nice i am wainting for new solar pannels to test it in real life :thumbup: this converter also needs an new sealed case made from cooper and i need to remove the fan Attachment 4851Attachment 4852Attachment 4853 |
8 Attachment(s)
in car panel computer
modified eeepc 701 4G 7" display can be used to get real time data from controler using RTD Explorer power used less than 12W can be foud on ebay around 100USD now i need to find an case 225x140x40 for pc (i will use eepc LCD frame) i have ordered an touchscreen interface so thet you can access menus and type without keyboard price 30usd Attachment 4941Attachment 4942Attachment 4943 Attachment 4944Attachment 4945Attachment 4946 Attachment 4947Attachment 4948 |
2 Attachment(s)
update
144-12v 2x17A converter is almost ready (now packing in case for car instalation) 144-12v 4A for computer and controllers is ready (now packing in case for car instalation) 12-144v 500W inverter is ready (fets changed,transformators rebuilt) (now packing in case for car instalation) 220-144v car charger (testing small scale) 10-12batteryes BMS is ready (in testing phase) car computer is almost ready (waiting for touch screen) i will updload pictures later |
4 Attachment(s)
dc - dc converter is ready almost finished assembling it
now we have the down converters ready 144-12v 17x2A for lights and breaking pump 144-12v 4A for pannel computer and controller 2 independent converters in the same box i have removed impute ac-dc bridge and i am injecting dc directly into it i have also moved all power components to the big aluminium heatshinks Attachment 5005Attachment 5006 Attachment 5007Attachment 5008 |
2 Attachment(s)
waiting for the rest of parts
for now working on batery monitor we need to know if batteries are leveled so me measure each batery and use an 10 led bargraph to indicate its state 10 identical 12V bargraph voltmetters based on lm3914 bargraphs are easy to read when driving ! we have an digital volmetter to measure battery pack voltage (whole pack) and this bargraph to measure the remaing power for each battery we have chosen 10 leds bargraph (DC10GWA) with last 3 red to know when the batery is nearly deplition (11.2V) so that we will not destroy the battery also voltage levels can be ajusted individualy for separation we have used quadruple optocuplers (3 of them) to be shure that high voltage can not break anything this can be mounted on secondary radio bay or in our case in the center on console (where were old warning lights for preasure,etc...) cost for the whole 10 voltmetters is around 20USD Attachment 5011Attachment 5010 |
DYI Dolar charger
6 Attachment(s)
i blew the chinese 500W converter at tests with 200W halogen bulb in around 2 hours
upset i decided to build my own it consists in 3 blocks clock generator with 555 flip flop switch 1/2 of 4013 power block 2 BUZ48 for every 250W of load i have reused the old ferite transformer and rewired it for my needs i have tested this converter with 200W load for 1 day and is still working (not from the test battery but from my 12V 2x17A dc source ;)) for battery charger it needs an ac/dc rectifier and an operational as comparator (to monitor charging currrent and stop charging at full battery) final one has 4 fets (to be shure that it resists in time and prevent overheating) i have also added 2x200cm2 aluminium raditors now everthing stays at 43C price 18USD Attachment 5014Attachment 5015 Attachment 5016Attachment 5017 Attachment 5018Attachment 5019 |
This guy doesn't waste time!
2 Attachment(s)
Start investgating cheap/small brake pump
i have used an tire compresor that can go to 12 atm and reversed the valve now i am searching for an vacuum tank 1-2l so that we can stop the pump and start it only when preasure goes below 4atm the pump is realy small 80mm by 35mm and realy quiet (can be heard :( ) cost of pump with gauge 7 USD Attachment 5020Attachment 5021 |
3 Attachment(s)
finaly some progress
car came from painting ... now the real work begins |
that looks great!
1 Attachment(s)
finlay back is finished with tail lights
photo taken in midday with sun lughting from my back (cant be worse than this) now lets start building the front Attachment 6361 |
sorry to barge in on you (scuze ca dau buzna :D) but what else...I'm hooked to this now... :D
Have you tested your tire compressor vacuum pump further yet? I built one too, it went easily to 20 in/Hg. It wore out in use though, didn't build vacuum fast enough anymore. Had to get a "real" one from salvage yard. I used an old fire extinguisher as vacuum tank. Should be cheap, hehe.
I loved your idea of building led tail lights that way. I did the same: better than original. |
