Kamm back speed at which it starts to work?
I used to have a book that gave a guide to the speed at which the airflow held its shape, but I have misplaced it. Any references online etc. Cheers |
speed
aerohead -
CarloSW2 |
apex
Speaking of... In which direction does the BSFC curve shift/stretch as a result of a decrease in Cd?
To make an object stable while in motion, the center of gravity must be forward of the center of pressure. This is true for high speed automobiles, airplanes, rockets or javelins. Kammbacks are used in Top Fuel Funny Cars for two reasons. 1. to keep downforce or pressure on the rear tires. 2. To increase drag aft of the CG. In the movie World's Fastest Indian Burt Munro did a stability demo with a pencil, the pencil became stable when the CG was moved forward of the CP. Burt wanted to add weight to the front end of his Indian MC to shift the CG forward of the center of pressure, thus make it more stable. IMHO, dams, wings, spoilers, kammbacks are "thangs" that are used to overcome bad aero design. Anything and everything that has mass and moves in a fluid creates drag. |
Bsfc
kammback
-soD |
aero/BSFC
Of course, you can overcome that with Pulse & Glide....
So are you both saying the same thing...? That the BSFC curve doesn't actually shift, since that specifically has to do with the engine, but the entire driving system will bias itself downward on the map towards less efficient power? Or is the "load" on the BSFC curve based on the entire car (engine, gears, wheels, and all) so that the map will change since "the car" has changed?
Sorry this has gotten so far away from Kammbacks! CobraBall: It sounds as if you're talking specifically about a "spoiler" of the kind that is placed at an angle to the airflow to create drag and force in a particular direction. I got the impression that Geebee was asking about a "Kammback" as a design that deliberately follows the ideal curve for some distance in order to avoid creating extra drag. |
'zactly. If you're running steady-state speed, you have lower engine load, which puts you into a less-efficient BSFC point.
However, for p&g, the pulse will not be much different than before. Maybe slightly shorter, due to the lower resistance, but not much. The big bonus is that the glide will go much longer. This biases the total more toward the glide-level consumption, raising the average. Glide-level being idle if you leave it running in N, or zero if you EOC. You would move from the red zone (best) straight down, based on how much less resistance you have. http://us1.webpublications.com.au/st...110216_9mg.jpg |
shift
akashic -
But I do think the segway is pretty interesting. CarloSW2 |
GREAT movie, it just shows how much (even though a little "hollywood") backyard "engineers" can achieve and what streamlined bodies and regeared transmissions can do- in the movie they use it for speed, but the same holds true for economy... In other words... I want a taller 5th gear! I can downshift, thats fine im not lazy... heck its an automatic it will downshift by itself common!!! |
To answer the original question, have a look at the aero/rolling resistance / fuel consumption tool I posted:
Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com The default values you see when you load the page are for a 95+ Metro hatch, but you can enter your vehicle's values if you want. You can see that aero & rolling drag are pretty much equal at 30 mph/50 km/h. But even at just 20 mph, aero drag still represents 1/3 of the total. Remember the comments on this subject from the developers of the GM Volt: Quote:
MetroMPG - Unless their engineers are anything like their management staff...
Person w/ the Toy PreRunner - If you have stake pockets in your rig:
You should see some kind of drag improvement by doing this, as it effectively creates a boat-tail of your bed, one of the easiest things to do to a truck. You will, however, notice less winter (snow and ice) traction at speed, due to the lack of downforce caused by the (add term here) effect, which creates an oblong air-swirl in the bed of the truck that helps to keep the rear planted at speed (see: Mythbusters episode on "tailgate down mileage savings") I'm not sure if that's a misconception though (the traction thing). Although at first glance, it seems plausible, since it's a high pressure area. Anyway, give that a shot, you might like what you see. If it works out for you, it's easily removable and replaceable, should you need your entire truck bed for something, and you could easily make an aluminum button frame and cut/sew a canvas or other material for it. |
OP - sorry about that. I have no idea when a Kamm is most effective, but I know the theory and practice of it's application, based on information attained from this site and other sources. None of which are personal experience.
General population - Braingle: 'Tailgate Flap' Brain Teaser
In my build thread, you can see some "teardrop analysis" and discussion of my options re: a Kamm-style chopped boat tail to work for my shortbed. |
K "Rik", yeah, I meant a shell :P Good work on your truck though.. your avatar image doesn't show it, so I didn't know about it. :turtle:
EDIT - I guess it does... mibad, I just saw a plain ole' Toy in that image.. I guess the mind really does see what it wants. :rolleyes: |
2 Attachment(s)
Drag Racer Don Schumacher's Vega Station Wagon called the "Wonder Wagon" did not last very long. The truncated 2-door had a bad reputation of poor handling near the finish line. Don kept the name and switched to a coupe. 0.37CD is the same as the Volkswagen Tiguan (SUV). Always thought SUV, aero & CD in the same sentence was an oxymoron.:) A true Kamm Back has flowing tapered lines and then sharply truncate the end. The best racing example of a Kamm Back may be the Shelby Cobra Daytona Coupe (below). Others examples are the 1970-86 Citroen GS, 1984-91 Honda CRX, 1992-98 Mazda MX-3, Insight, & Prius. Professor Wunibald Kamm, head of the Automotive Research Institute at the Stuttgart Technical College developed his Kamm Back theory to shorten the length of a tear-drop-rear-end design and still have a good aero/CD. The Fastest Indian was a little Hollywood but Burt took his Indian Streamliner Motorcycle to Bonneville 12 years in a row. The movie had to condense the 12 years into 90 minutes. Burt is one of the true LEGENDS/ICONS of high speed racing.:thumbup: IMHO if the Kamm Back was the answer to an aero rear end design, then high speed bicycle and gravity racers would use a Kamm back in lieu of a tear-drop design. |
http://ecomodder.com/forum/member-ae...-kamm-back.jpg Quote:
The Kamm back is the answer to good aero design in production vehicles where (a) it's not practical to extend the vehicle's lines to the ultimate teardrop end, and/or (b) where consumers would likely reject a full or near-full tear drop as too radical. HPV's, gravity racers and solar cars don't face either of those constraints. |
1 Attachment(s)
MetroMPG,
Thanks for the picture of Dr. K's K-car. My mistake. After the 1934 Chrysler Airflow was introduced, the Auto Design Institute retired the "THE BUTT-UGLIEST " trophy :p to permanently to the Chrysler Design Studio. |
First time I heard/read K-car: I thought of the Plymouth Relient. Not exactly an aero wonder, if yaknowuddimeen.
