Is Keeping Your Old Car Better for the Environment? by Engineering Explained
YouTube notified me after 2 days!
He said that if your car gets 40+ drive it for as long as you can. https://www.youtube.com/watch?v=L2IKCdnzl5k |
Now I have to keep my cars forever! I think compared to electric he said 7 years. 2028! Here I come! |
I've tried, but nothing lasts forever.
https://ecomodder.com/forum/member-f...4-11-26-01.png The biggest problem is having too many. https://ecomodder.com/forum/member-f...02-1-29-33.png https://ecomodder.com/forum/member-f...-outa-town.jpg |
Even if a beater would require some extensive repairs to remain beatworthy, often it's still less energy-intensive to fix than looking out for a replacement. Even using a lower-grade sheetmetal to patch a rusty body becomes reasonable to some extent.
Everybody hates my old cars, but only my Subaru was unreliable. I wish the heater core had not gone out in my Civic, but I wouldn't have blown the heater core if i took proper care of my car.
I've calculated that it would take a Tesla roughly 25-30 years to make up for its production emissions compared to my used MR2 Spyder.
That is ignoring the fact that the Tesla will likely not last 28 years, much less on its first battery. It is also ignoring the possibility of me converting my car to run on biofuels or doing a hybrid conversion. So, I'll keep my Spyder, and I'll keep my bicycles. If I'll end up needing to drive more, I will obviously consider going electric. |
Jason claimed that Americans average over 12,000 miles a year.
That seems out-of-date. I am sure that some people are driving as much as ever, but I drove to see eleven clients each week in 2019, but I only see one-client in-person now. I went from spending as much time driving as actually conducting therapy to a fraction as much now. |
I thought he said that 12,000 was a actually lower than the average, which gives the "keeping your old car" an advantage. The less you drive them more sense it makes to keep your older car longer. If you're going to drive a million miles a years you'd probably be better off with the newest and most fuel efficient vehicle you could find. (Except an EV probably wouldn't be a good vehicle to try to drive a million miles per year in.)
Just for fun I calculated the average (!) speed you'd need to go for that, wich is 114,2 km/h. Let's say you actualy drive 12h/day on average instead of an impossible 24h/day, you would need to average 228,4 km/h for 12h per day. Wich would be hard in just about any car short of some Audi with a large diesel engine doing circles in Nardo. But then again, I'm not sure if the engine would even survive that kind of torture... |
There was a proposal to not have mineral oil tax on biofuels, wich they voted against. Their reasoning was that we should focus on electric cars instead, wich we should indeed do, but that doesn't mean all ICE cars instantly disappear from the road. Cars have a lifespan and we're still building ICE cars, if we want to reduce CO2 emissions, using CO2 neutral fuels for them is a significant factor. Although having mineral oil tax on non mineral oil fuels is a little obscure to begin with if you ask me.:confused: |
I always hear that environmentalists oppose clearing out forests.
I don't like forest fires! Who does?! Environmentalists?! Apparently environmentalists have been cooperating with fire prevention: https://www.mercurynews.com/2018/11/...try-practices/ |
However they haven't realy trickled down into the used car market yet, or at least the ones with good range. Taking a 20 min charging break every 400-ish km or 3-4h of driving isn't realy something I'd consider big of a deal as I'd need to take a break at that point anyway. |
On topic, an ICE can be converted to wood gas. I'll not sure to how that compares to running electric off of wood. |
1. It is very inefficient 2. It requires a somewhat elaborate starting procedure 3. It reduces an engines power output massively 4. It makes your oil go acidic rather quickly 5. The emissions of an engine running on wood-gas are terrible Use that plant material to make ethanol instead.:thumbup: |
https://1.bp.blogspot.com/-VzaSwiHNY...direito%2B.jpg |
Here in germany it's normal to have 3-phase running to your house, wich means you can usualy install either an 11kW wallbox or an 11kW power outlet. So you can charge even a 100 kWh battery that has been drained completely over night. With cars like VAGs ID-series, Teslas Model 3/Model Y and so on, you can see prices going down to more average levels. In a few years these cars will end up in the used market as well and be reasonably cheap. |
In Mexico you get a 110V (or 120V?) service with only 30 amps total for the whole house.
In the USA a lot of us rent our homes/apartments. And even if we do have a way of installing a charger it is usually harder to get much more than 240V at 30 or 40 amps (well actually 80% of those amps or 24 or 32 amps respectively). The more you go from there the more likely you need your house service upgraded (total amperage at pole to home) although some homes may need an upgrade even with a 20 amp (16amp) increase. |
With 110V and 30A, you've only got 3,3kVA for the whole house. A normal power outlet here has 3,5kVA (maximum, not sustained). As for 240V, single phase systems, for that kind of power you'd probably want a higher voltage/more phases as that would require rather thick cables. What where they thinking with this whole split-phase 110/220Vsystem over there? 3-phase 220/380V is more efficient and requires less copper for a given power requirement as well as giving you the option of running 3-phase motors directly from the grid. Plus let's not forget that you can run RCDs from the breaker box. /rant |
We get a lot of wildfires here in Arizona.
There is a study by the university of alabama showing comparable emissions to gasoline on an older (90's I think?) dodge v10 and 37% more efficient than gasoline. I have to leave for work, but I will find the link to the study. |
And that 30A is max, not sustained. Sustained is 28A, or about 2.6kW continuous. FOR THE WHOLE HOUSE of course. It's also common to see two (or more) households using the same fuse box (no breakers down there). It's also common for people to steal electricity by throwing hooked cables up onto the street cables or by placing jumpers behind the electric meter. I've also known of more electrical fires in Mexico than in the USA. |
1 Attachment(s)
Google says that the Secretaria de Salud is Mexico's equivalent of OSHA, but something tells me that you cannot compare them.
Actually, many things tell me that, including this picture: https://ecomodder.com/forum/attachme...1&d=1632272654 I feel that if they were team players one would be standing in the basket and the other would be pushing it and passing up stuff. Are shelves taller in Mexico? I always laugh at the signs in Walmart to get help getting stuff off of the top shelf. Why? I can reach it. They probably can't. |
https://www.driveonwood.com/static/m...nal_report.pdf
I was mistaken on the vehicle. He also has a dodge ram 3500 that he uses on his farm. The test was conducted with a dodge dakota, should be the v8 in it, not the v6. Towards the end (pg 10): Quote:
(this will be my last off-topic post) |
better
I'm thinking of it along the lines of COVID.
We have a CARBON-64 vaccine, which will kill the carbon dioxide pandemic scientists have been warning us about since 1957. EVs. Vehicles with carbon comorbidity issues might be prioritized on an mpg basis. Those with the lowest fuel economy would be triaged for immediate 'vaccination' and retirement from service. Recycled. Replaced with a zero-carbon vehicle. On down the line, on an efficiency basis. The least-offensive emitters are the last to be electrified. Say, a Plug-in Prius, @ 55-mpg. Carrots are favorable to sticks. Incentives. Wrap it up in the flag and make people feel good about the whole thing. Sicily hit 122-F in August, an all-time heat record. Avocado and orange production suffered. Farmers who could, dug reservoirs, as ground water is now 'iffy'. If they have another year of drought, it's game over for agriculture. And we continue to add carbon, doing nothing to remove what's already there. Removing carbon IS the solution according to climatologists, but first we've got to stop digging the hole we're in. 40-mpg is good but it isn't zero. |
"Tortilleria"?
I liked this Kurzgesagt, not only because the animation is done in Blender*: Can YOU Fix Climate Change? But then, at the end, you find out it's sponsored by Bill Gates' GatesNotes. Now, when I don't know what to think I fall back on Bucky Fuller's Design Science Revolution, *Froop Poop :) |
obesity..........injections
I don't believe we're authorized to address these sorts of issues, as we'd have to venture into all the areas which are specifically taboo.
But what you've said sounds like a total mess. |
I don't mean to make some sort of a stereotype, but from what I've heard it seems pretty much all Central and South America have about the same electrical systems. I don't forsee any sort of a mass migration to plug-in vehicles any time in the near future in those countries, except maybe for public transport only.
That means phases are 180° seperated with a neutral in between. So they get 110V+110V, plus if a hot wire is touched and a ground fault created, nothing is stopping it unless there is so much current flowing through the poor individual touching the hot wire that the fuse blows. Here in europe we have 220V phases and 380V 3-phase, we also have RCDs in the breaker box wich stop the current after miliseconds even if its only a few mA. |
There are so many strange makeshifts I see almost every day, and some might be relatable to cars so there might be space for them on the forum.
I'm sure keeping something like this...
https://1.bp.blogspot.com/-_fOB9of01...ro-direito.jpg https://1.bp.blogspot.com/-3CoVrElR3...ro-direito.jpg instead of replacing with something like this... https://1.bp.blogspot.com/-trV0dGVKc...olis%2Bfrt.jpg https://1.bp.blogspot.com/-0U-fERaLQ...olis%2Btrs.jpg could make more sense. |
