Old 02-11-2011, 03:34 PM   #1 (permalink)
EV motor help treadmill motor?
I have two industrial treadmill motors could these be used in VW bug to make a EV. They are 180VDC 2HP 9.5A. see pictures
http://s1226.photobucket.com/albums/ee404/ttward2/
The Following User Says Thank You to ttward2 For This Useful Post:
rvind2008 (05-23-2011)
Old 02-11-2011, 05:18 PM   #2 (permalink)
Zed - '11 Honda CR-Z
90 day: 43.91 mpg (US)
Most likely not. At a guess I would assume they are permanent magnet motors, and are probably not going to be able to produce enough torque, let alone deal with the internal stress that would be put on them in a hybrid situation. Now there are PM motors on the market that offer some potential for being intergrated in a hybrid like E-tec/Mars motors.
Whenever you are looking at an electric motor/drivetrain specs the general rule of them is;
Volts = RPMs
Amps = Torque
So when you see specs like what you presented they look like motors that can spin real fast, but not move much, which will be very necessary in a hybrid situation.
The Following User Says Thank You to Cortez For This Useful Post:
Old 02-11-2011, 05:38 PM   #3 (permalink)
Thanks for the info. my next project is a wind turbine.
Old 02-11-2011, 06:11 PM   #4 (permalink)
dude...wait...what?
Odin's Avatar
Diesel Rx-7 - '82 Mazda Rx-7 GSL
merc 300d - '82 Mercedes-benz 300d dt
b2200 diesel - '84 Mazda b2200 D
you might be better off using those motors for the wind
The Following User Says Thank You to Odin For This Useful Post:
