Kinda ScanGauge w/o OBD
Hi there!
Is there any kinda equipment like scangauge for cars without OBD? No electronics at all. The only one I know is the vacum meter. Thanks! |
...how far back year-wise are you talking about?
...if it's got electronic fuel injection of any sort (throttle body, manifold, etc.) then possibly the MPGuino is usable? ...if it's straight carbureted, you might have problems. |
It's an old diesel engine from 1992 a ford fiesta 1.8D, I think the vacuum is the best solution right?
Does the engine have a throttle? If not, a vacuum is pretty useless.
But you can plug a vacuum meter on the brake vacuum lines right?
Won't it give the right data? |
...you really want to measure how hard (or not) the engine is "working" not the barometric atmospheric pressure that tells you the altitude. |
But i fitted on a gasoline Seat Ibiza like i said and was working! It connects to the intake manifold! Right?
So can do nothing to scan anyway the engine? |
A gasoline engine was vacuum in the manifold, that's just the way it works. This vacuum can later be used for brakes, etc. In a diesel there is no vacuum, so the brake assist has to be generated by an external pump powered by the engine. A diesel would work just fine without the vacuum pump, in fact it would have that much less load on its accessory belt or camshaft.
If your diesel has a turbo, then you can monitor the intake air pressure. It's not much, but always something. |
Thanks mate but I really wanted to control the engine load so could make my driving as economical as possible!
What if there's a kinda flow meter that connected to the diesel intake and the diesel return would make an intant and average fuel consumption? Is there any kinda thing that is possible to fit in a car like mine? |
On an older naturally aspirated diesel your throttle position determines fuel flow rate (newer it depends on throttle position and RPM)
Figure a way of knowing exactly where your throttle is and your halfway there. And yes there was a fuel meter made for measuring the amount of fuel into the engine but likely you would have to find one in an antique shop, perhaps monitoring your injector pulses with an MPGuino would work well enough? Good Luck Ryan Quote:
My idea with the flow meter is this: - If you know the amount of fuel that's going to the pump - If you know the amount of fuel that's returning to the tank pumpin' fuel - returning fuel= injected fuel That injected fuel on that precise moment (milisecond, second, hour, minute, whatever) is the one used. Okay... If you go @ 100km/h and that fuel used is i'd say 5l/h then you have a fuel consumption of 5l/100km Am I right? Mate there's a big problem on that, my car is old injection pump, don't have any injection advance, all mechanical, but that wold really work! What kin of antique shop intrument are you talking about? never seen it, could you help me please? Thanks a lot mate! |
Anyway your motor if stock has a very specific amount of fuel it uses at idle and a very specific amount it uses at WOT, my 6.2's vary by year as toward what those were but as long as the motor is warmed up and not turbo'd fuel consumption at a given throttle position stays fixed except at extremely low and high RPMs. In other words you would have to look up what they are for your motor and have a way of extrapolating your FE from your current speed and fuel flow rate. Good Luck, this is really what I would like to see available for Diesel FE since there currently are no good and moderately accurate solutions. |
Right so by the rpm and throtle position is possible to find the fuel consumption!
There's a speed sensor that is easy to fix in my car's gearbox and give speed by voltage! I have to think about a thing like that and I'll search the classifieds! The volume of air is not dependant on the throtle position, if you go @ 40km/h in 5th gear and the engine really allmost "dead" if you press full throtle you get full pump injection but the volume of air stays allmost the same! |
from a vacuum gauge to this ...
if you are just looking for a relative value as a vacuum gauge would sorta kinda provide in a gasoline powered engine ... you can plumb in a MAF sensor , any MAF sensor into the air intake , they have a 5 volt reference and a ground and a signal which you will need to provide a power supply for some have a temp sensor as well just monitor the MAF signal lower = better FE Quote:
That isn't true of my 6.2, the amount of fuel injected is limited by the type of injection pump, more rpms at WOT and the pump can't put in anymore fuel as it hits the limit around 1800rpms. Might be why my motor is only 120hp and newer versions are 165hp both NA. Also explains why I initially get a initial puff of smoke which clears as the motor revs at WOT as the fuel volume can't increase due to the injection pump flow rate limit. (REMEMBER I DON"T HAVE A TURBO) |
I'm looking for a way to tell me the best FE.
I'd like to try a live fuel flow meter, like the mpguino and a pcb etc... |
