know the object more aerodynamic
Hello everyone! if I have two objects in 3d format obj or stl, with which software can I know what is more aerodynamic? thank you
What is the best open source CFD Software? SU2, OpenFOAM, ...
Good luck ! Also, if you are a student, you can get a ( free ) 3yr license to this one, in which the learning curve is about 1 - 1/1000th the other software mentioned Computational Fluid Dynamics | Simulation CFD | Autodesk |
Unless you have massive computing power I would look here:
https://www.google.com/search?q=CFD+in+the+cloud |
I ran across this link a few months ago. It might be helpful :
https://www.cloudcfd.co/pricing.html BTW : It's jumped up in price five times over since then ! |
software
Dr. Teddy Woll,of Daimler-Benz says that Mercedes-Benz is using it and it is within 1% accuracy of full-scale wind tunnel tests. With a supercomputer,a digitized automobile requires about 48-hours run time due to the mesh size,and time steps required for this full Navier-Stokes solver. Desktop CFD has shown errors of 13%.They DO however show definite 'trends' in performance. |
