Koenigsegg camless engine and compressed air hybrid
You can skip the first couple of minutes, the interesting bit is toward the end.
http://www.youtube.com/watch?v=Bch5B23_pu0 |
Fascinating stuff!
I've been thinking about doing just this sort of thing! Too bad I didn't have all the money ):
super cool
Finally getting rid of the cam shaft. Amazing it took so long. One day. all but the cheapest engines will have computer actuated valves.
My question is this: where does the air pressure come from? Would electric actuation be more or less efficient?
From turning the engine into an air pump on deceleration. And I presume there's an ICE driven pump for air demands outside of decel...?
You are probably right, I wonder if there's any tricks to starting it up if the cars has been sitting for a while. I suppose it would have to always keep some pressure built up for the next startup, until the compressor could build up more pressure. As a supercar I would imagine that it sits parked far more often than it's driven, I wonder if there are any tricks to it like relieving pressure before storage, and building up more before startup. Although they could avoid that if it used an electrically driven air compressor that could run for a second before firing the motor.
Coates International Ltd. - Home No cams... The Koenigsegg video is very cool and has a nice explanation on how it works. But, it's not exactly new... BMW had a functional protype (using electric solenoids IIRC) about a decade ago. Still hasn't made it to production yet. |
Interesting - 30% better FE with 20% more power etc.
starts to look very promising. |
That's the beauty of getting rid of the cam shaft. You can have the most economic valve timing profile one instant and crazy high rpm peak power the next.
I'd heard the problems with the BMW system were that it couldn't reach the same engine speeds that you could reach with a cammed system... but for roadgoing economy engines, that's not a big deal, I guess.
What's most impressive with the Koenigsegg video is that they say the test mule has already done 60,000 miles over two years. Still not a lot of miles, but that's a good sign. |
I remember Porsche was developing a cam-less electromagnetic valvetrain a few years ago. It was supposed to deal better with higher revvings than a pneumatic one.
So I was totally going to post this video, and then thought "I should do a search to see if someone else posted this."
Turns out someone had. What an awesome technological innovation! EDIT: for the lazy |
Is this the car with four hundred carbon-fiber components? I watched a video on YouTube where they showed the carbon fiber valve cover!
I LOVE Koenigsegg. They are so fantastic- a true super car, McLaren F1 style.
Thank you, OP. Quote:
It may not be the first of its kind, but it doesn't seem like anyone else has put it in a car, and had it successfully work for over two years and almost 40k miles. |
I also think its amusing, their top speeds. What is it? "Oh, it goes past 240. " Well, how much faster? "We didn't bother checking the max, but it goes that fast." (Not direct quotes, but from what I read, thats how the conversation goes :) ) |
Still, it's great to see that they've been running camless valves for 2 years, I'm sure not many other companies can say that. |
Not always is it accurate, but it's defined- of course wind, direction, temps make a difference, but they state a number. I have never weighed myself and thought "greater than 200" or think of my fuel economy as "greater than 30." The generalization of it implies that such a large number is meaningless- which I think is funny. |
