EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Latest Aero Mod (https://ecomodder.com/forum/showthread.php/latest-aero-mod-5517.html)
BBsGarage 10-13-2008 08:12 AM
Latest Aero Mod
This has been on my todo list for a while, and then seeing chuckm getting it done lit the proverbial fire :D
here are some before and after pics of the large gap from the radiator bulkhead to the front fascia.
http://www.sippingfuel.com/pics/front_under1.jpg
http://www.sippingfuel.com/pics/front_under2.jpg
I used some thin sheet steel. If it actually helps I will clean it up and probably paint it.
vtec-e 10-13-2008 08:38 AM
Neat looking job. You could have kept going though and cover the whole engine underside! Combine that with an 80 to 90% grille block and you'll have a toasty engine!!
ollie
Daox 10-13-2008 10:21 AM
The Matrix has the same opening. Its kinda odd IMO, especially since it has the underbody panels just after the radiator support.
chuckm 10-13-2008 06:52 PM
Looks good! Much cleaner than my job!
cfg83 10-13-2008 08:36 PM
BBsGarage -
I like it a lot. It's also on my todo list. Most mods under the car get short shrift from (lay-zeeee) me.
CarloSW2
Xringer 10-13-2008 08:37 PM
Dang, that's a big area! They should have done that job at the factory!
(It looks factory)!
