EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   leanburn, on other engines? (https://ecomodder.com/forum/showthread.php/leanburn-other-engines-16450.html)
bandit86 03-14-2011 04:04 PM
Is there anything special about the honda leanburn engines internally? I mean, why do they not suffer from lean run condition that ruins other engines?
Tygen1 03-16-2011 12:44 PM
Lean burn can be done on other motors, just not quite a lean as Hondas. I run mine around 16.5:1 without any problems so far, although I only do this while cruising.
Ryland 03-16-2011 04:05 PM
combustion chamber shape and size play a big roll in being able to have lean burn.
nemo 03-19-2011 09:06 AM
Wards Auto Logo Mercedes Says Dirty Fuel Problematic in U.S.
Looks like sulfur content may play a part in why we don't have more lean burn engines in the US.
D.O.G. 03-19-2011 06:17 PM
Home made lean cruise
I'm into the second tank of testing a very basic lean cruise setup on BoB.
I use a digital vacuum sensor on the distributor vacuum advance line to switch a solenoid valve that allows some air to bypass the carburettor at cruise. I also run a basic water induction setup to keep temperatures down.
I don't have EGT or AFR gauges so I'm taking small steps until I get some useful figures to work with.:)
