Learning how to make a brick "sleek"
Hello all,
I've been avidly reading threads here for the past week or so and finally decided to join. I don't know how much of an ecomodder I am, but I definately like saving money at the pump! My goal in joining here is to learn how to set up my 2000 Cherokee to get something higher than it's abysmal 17MPG it currently holds on to. It won't be for a while yet that I get to work on it, but I can at least draw up the plans and get a good parts list. I still like taking it offroad and such, but when I go across the country, it would pay dividends to be able to get 25 to 50 percent better gas milleage. I'm designing quick release eco components that can "attach" to my bumper system and frame. I don't have one of the scangauges that are so revered here, but my Bullydog Econometer does most of the same functions (though it's still in the box as I've not been able to install it yet).:D |
JeepNmpg2 -
Welcome to EM! Just off the top of my head, I think Big Dave has lot's of great truck mods to study. CarloSW2 |
...a "slick" BRICK?
Welcome to Ecomodder!
Glad to see another Cherokee on the forums. |
If that's your Jeep in your pic, I would say... Get rid of all that extra that didn't' come on it, and put on road tires.
...MORE weight = LESS mpg.
...in the 3K lb range, the relationship is approximately: (wt1/wt2)^(0.72) = (mpg2/mpg1) |
One thing to remember is that everyone here isn't going for "absolute economy," as I personally am looking to compromise in using removable eco-components. Since this rig is my daily driver (and my commute rarely gets above 35 mph for now) I don't anticipate ecomodding it out. HOWEVER, I do have plans I'm drawing up to fab when I get back for parts that I can install for longer, highway/freeway trips. Remember, I'm trying for a best of both worlds approach, not to say I might not remove the offending roof cargo rack for a long trip if not in use or I can't ecomod around it (which I'm still dreaming up now). I know I can't have everything, but I do know what I'm not willing to give up, so I need to compromise for them. |
JeepNmpg2 |
Of note, I like your solution for the front radiator vents. I have that bullbar in front, I'm going to try to create a modular "over box" that would sit over and through tbe bullbar up flush with the radiator intake. I'll make vents on the sides so that the engine can suck air if it needs cooling but at highway, it shouldn't need that even. One more mod (I should probably do it in conjunction with the air box) is to upgrade the pulley driven fan to an electric model. I found a more than capable dual speed one out of a 94 Ford Taurus (and should fit according to a write up I found). Well, this post is long enough, thanks for the input FastPlastic.:D |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
