Old 05-03-2009, 07:20 AM   #1 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
Center caps fill-painted
Stock: Civic HX center caps not filled
I thought the "H" needed to be blackened.
Yes the wheels need repainting but that's beyond what I'm ready to do now. I do like the caps though. I used acrylic paint from a craft store.
Coast long and prosper.
Old 05-03-2009, 04:30 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
So you just painted it on with a brush?
Old 05-03-2009, 07:09 PM   #3 (permalink)
brucepick's Avatar
Gen-1 Insights
Yes, brushed. Just let it fill the recessed "H". I had to wipe the high spots clean, that was the toughest part - wipe it without dragging up more paint from the recess. Let it dry (just a few minutes once I got the dilution right), then repeat a few coats as needed.
Yes, spray could give a cleaner surface. I figured shucks, it's black. If not glossy, perfection in the finish won't be an issue.
mileage is mileage, right? (question about accuracy of small fill) Chris D. General Efficiency Discussion 16 10-21-2008 07:59 PM
When to Fill up trikkonceptz Hypermiling / EcoDriver's Ed 5 05-05-2008 08:14 PM
Solid wheel caps (moon discs - where to get?) NoCO2 Aerodynamics 48 02-12-2008 05:23 PM
