lets see your Aero mods
Here is my 2013 Insight grill block off using cardboard for mock up will be making one from aluminum shortly ....now lets see your mods
http://i742.photobucket.com/albums/x...323_191559.jpg 2" drop http://i742.photobucket.com/albums/x...222_124623.jpg |
Good job 0n the belly pan and the rear wheel strakes, in particular.
Nice fun thread idea... subscribed.
Here is one of my favs: lower side skirts made from painted and then plasti-dipped rain gutter. But I have had difficulty with attachment because I insist on using free leftover hardware, lol. I'm thinking of using a little of my double-sided automotive trim tape to better secure it. Thoughts? http://ecomodder.com/forum/member-ca...flat-black.jpg |
http://www.homedepot.com/p/Scotch-1-...1-DC/100575385 Does the oem sideskirt have any existing holes on the bottom to use as mounting points? |
I'm working on a belly pan and something for the rear. These are my current aero mods.
http://img.photobucket.com/albums/09...odslabeled.jpg The side skirts are Coroplast. The splitter is the top of an extra bumper cover. The tire deflectors are baler belting. The wheel covers are plastic serving trays. The grill block is cut from a pickup truck bed liner. |
With my rear wheel boat tails and side skirts, my car looks a bit "empty" on the front bumper |
Hey gasolinefumes, what function is the solar charger for? Battery? How well does it work for you?
Oh! And jdeisol, yes the OEM underside is painted, but by me, with plastidip... probably not good for any kind of tape, eh? |
This is the one I bought, but sometimes I wonder why I didn't just buy one from Tractor Supply or Harbor Freight that comes fully assembled. http://www.goldmine-elec-products.co...?number=G16130 |
1 Attachment(s)
Here is a pre-view of my Kamm-back project. These are two panels being held in place prior to attachment by the makeshift jigs I made.
2 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1511723221 http://ecomodder.com/forum/attachmen...1&d=1511723254 |
Gasoline Fumes, that is some exceptional mileage from a Civic Wagon, especially considering your location and the weather this winter.
regards Mech |
Not hard to get good MPG with Hondas my wagon was getting 40MPG easily
How did you attach it to the bottom, and how much did it raise up your mpg? |
Other factors were involved, so I can't say for sure, but it seemed to give me about 5 MPG at around 55-65 MPH on highway trips. And that's compared to an airdam I had on it before. I barely believe the results myself. :) |
Here is the aluminum version of my grill block off. I used the license plate bolt location to bolt it to the bumper
http://i742.photobucket.com/albums/x...331_182120.jpg |
This thread is awesome, I want rear wheel strakes so bad now it hurts. Lol.
barely believe
800 miles later not bad for cardboard and duct tape
http://i742.photobucket.com/albums/x...405_193640.jpg |
Gasoline Fumes -- That's apparently quite effective. What was the previous air dam like? The hood and fender gaps are tightened up in the later picture. Did that and the tire deflectors get you to 70mpg?
http://img.photobucket.com/albums/09...odslabeled.jpg http://img.photobucket.com/albums/09.../splitter2.jpg Quote:
http://img.photobucket.com/albums/09...tirespats1.jpg http://img.photobucket.com/albums/09...tirespats2.jpg My guess is that most of the air was still getting under the car. Those gaps are just because the bumper wasn't bolted on yet. |
Do you plug it into the power outlet in the dash, and leave it plugged in all the time? |
Partial upper block, lower block, air dam.
http://i799.photobucket.com/albums/y...r/NCM_0072.jpg Older style mirrors. Only swapped because one was broken and I need to get it inspected. http://i799.photobucket.com/albums/y...r/NCM_0101.jpg http://i799.photobucket.com/albums/y...r/NCM_0102.jpg http://i799.photobucket.com/albums/y...r/NCM_0103.jpg http://i799.photobucket.com/albums/y...r/NCM_0104.jpg I also removed the mud flaps and I keep the antenna and wipers in he cab. Oh there's a hard tonneau too. |
Just realized I have no pic of my air dam. Just imagine the first pic with a piece of gutter guard.
This was Version 2 of my grille block. Duct tape over cardboard for testing purposes. Survived 2 months of rain, then ended up getting soaked. V 3 will be coroplast and will happen soon!
http://i.imgur.com/mnUWQTi.jpg |
Emre2blue, nice diffusers.
Why did you narrow the channels of them? |
1 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1397789509 |
Have you tried placing them on the top of the glass? That's where they would need to be on my car because separation starts about the midddle of the backlight. |
1 Attachment(s)
[edit] took a picture of the fairing. Yellow line is the part that broke off. Red circle is a metal screw that it pulled away from. The fairing also twisted about 90* after I hit the curb, and then backed away. Fortunately, I was able to turn it back and retighten the attach bolt. As I was musing on this today, it occurred to me I could get some rubber wall border and use that as the bottom 3" which would keep the bottom flexible while still deflecting airflow around the tires... |
This thread has me interested in splitters now. Need to do more reading and then build one. Friend has a whole bunch of plywood laying around from a shed he's tearing down. I think I need to grab a couple of sheets and start playing around...
Here is my "stealth" upper grill block. Coroplast from behind, glued/sealed using caulk; http://i40.photobucket.com/albums/e2...pstxgjlawo.jpg |
Sometime soon, I'm going to contact a local semi truck trailer outfitter, and see how much the rubber skirting they put on the bottom of trailer wings would run me... You know, scrap pieces. I think that would have the rigidity needed. Probably out of my price range, but, you know, it's a thought. |
