Life isn't always easy....
Hmm, potholes vs nearly unlimited solar generated power, I think I might tolerate potholes :D
You are absolutely right here dude.
Hang on. 9600km is around 6000 miles, right? There is a road in Africa that long and ALL of it is potholes:eek:?
I've been to Kenya and just about every road looked like that! But that was about 30years ago so maybe things have improved:rolleyes: |
But I suspect the sign in the picture has been modified... if not in the real-world, then in Photo-shop! (The vehicle registration is Gauteng province, South Africa) :rolleyes: |
But if you are in the sticks, no tailgaters!!!! Just drive whatever speed you like to not tear up your equipment!
From people I know that have driven in Africa at night, DON'T!!! The wild animal crossings will for sure customize your front end!!! |
I was fortunate to live in the South where people are generally much better off!
Its bureaucracy and graft that are the biggest problems... Give people the freedom to make money and they generally get on quite well! They don't need aid - just fewer politicians, priests and other thieves/paracites! |
Poli=many
tics=blood sucking leaches regards Mech |
I've seen worse than what's on that picture on Belgian highways ...
Including a stretch of asphalt that got completely torn apart within 24 hours after the repair job got done ! They blame it on a few harsh winters here. Yeah right, Scandinavia has better roads despite far harsher winters every year ! |
As for making the world poorer, how about a world in which a person can travel from Shanghai to Tahiti to Timbuktoo and find the same shops and goods - from fast food to high-end designer clothing - as in his nearest urban center? Seems pretty impoverished to me - the more so as the goods and culture seem to be reduced to the lowest common denominator. |
