light wheels
Just bought a set of centerline storm wheels. Weight 11.8 lbs. My original wheels weight 26.5 lbs. Might be awhile before I install these but I am guessing the weight difference should make a big improvement in a lot of different departments of performance.
Better braking, handling, acceleration (noticeably, even) and less unsprung mass. They'll suit you well.
Thats awsome. 14.2 lbs off per wheel, that should be good for some mpg.
I'm still on the fence regarding wheel weight and mpg. In theory it should make a big impact but in the Prius world it doesn't seem have much of and effect on mpg. I'd be curious to see how they work for you. Hopefully you will use the same exact tires to rule out any variables there.
Best gains would be seen if you did a lot of stop and go driving.
You'll definitely feel the difference.
My summer tyres are some 10 lbs heavier, and I feel that through the power steering ! |
Lighter is better. Tall tire test.
1 Attachment(s)
11.8 lbs is incredible light. Nice upgrade !
IIRC for every 1 lb of rotating weight it is the equvialant of removing 7 lbs from the chassis. That being said, for each wheel you replace its like removing 100 lbs from your car.
OP where did you get them and in what size? I'm also looking for a light pair of wheels and like these. |
I think the bigger factor is tire friction and hysteresis. |
What I have noted about 17's is that with lower profile tires you normally will take a hit in compound (softer) and load rating (lower). Both can affect mpg negatively.
Larger wheels push more of the weight toward the outside of the package, which gives it more of a levered advantage, and takes more energy to start/stop. On most combinations, the tire makes up at least half of the weight of the total package. Do you want that weight all in a very compact area? The plus side to lower profile tires, however, is that you can generally move more quickly through curves - less slowing down and speeding back up. |
WHERE you take the weight from has more to do with total performance than HOW MUCH weight you take off. |
Bought wheels at this site...ww.wheelandtireguy.com/products/Default.aspx?cid=46&clev=1
So, maybe I'm missing some key concept here - while what everyone has mentioned seems pretty on target, I haven't seen anybody address the fact the the prius picks up a serious bit of it's fuel efficiency due to the elec motor. The motor starts the car moving, and starting from zero is one of the more wasteful bits of driving - which is why stop and go is absolutely awful for your mpg. Since the electric motor starts you off, the lightweight wheels won't have as great an effect for a hybrid (my thoughts, not verified, not claiming it's fact). Seems to me that on things like a prius, while you might see small gains (although if what everyone is saying about heavier wheels kicking more juice back via regen. braking, then heavier might work better that way) from lighter wheels, you'd do better to get some taller (overall) wheel/tire combos, and work on aero.
My .02 |
My confusion comes from the fact that taller tires tend to help fuel economy on a fixed gear transmission by reducing cruise RPM at a given speed but on a CVT-like system what is the effect? |
I use the stock Corolla steelies for my winter tires and Prius wheels for my 3 season tires, both are 15". The Prius wheels are ~14lbs while the stock steelies are ~21 lbs. I notice a pronounced difference between the two straight away after the swap, in the handling/steering response department as well the car's pep starting off even when driving conservatively. I know the winter tread/compound are completely different, but it is remarkable regarding the dead weight even picking them up and mounting them. :eek:
Tuneko Ltd has designed new TuneCover - hubcap range that will fit also on aluminium wheels. Purpose of these wheel covers are to protect the wheels outer edge from curbwall hits but also to save fuel. Fuel savings are from 2 to 5% depenging on rims design. Fuel saving part comes from reduced aerodynamic drag on speeds above 80 km/h (50MPH). Car will also accelerate faster and the cars top speed increases.Check out their site good story on a vw lupo.
Tuneko, that's Vekke on Ecomodder ;)
So i had my tires installed today total weight reduction wheels and tires from stock 71 lbs! I've already seen big improvement in rural driving about 6l/100k from 7l/100k.Seems to coast so much better even though they are winter tires.
