EcoModder.com
-   -   Lightweight 15" wheel options? (https://ecomodder.com/forum/showthread.php/lightweight-15-wheel-options-15666.html)
ratherbehiking 01-03-2011 08:36 PM
Hey I just bought a Suzuki Sidekick and i am getting around 30mpg highway and one of the wheels is leaking air, so am looking to replace the set. current set up weighs 48 pounds per wheel. that is with stock steel rims and 205/70R15s. anyone know of any lightweight wheels that would be good to switch to?
alohaspirit 01-03-2011 09:45 PM
hard to find rims for a sidekick
bolt pattern is 5x139
(some jeeps, old F150, durango)
my advice would be to run skinnier tires
aggie sig 01-05-2011 09:26 AM
could you replace the wheel hubs with a more common size like 4x100? if so you can get some really lightweight import tuner wheels...
alohaspirit 01-05-2011 11:43 AM
i looked into that years ago
technically anything can be done
but it wasnt worth the time and money
