linear generator engine
I wonder what the net recovery to recharge the batteries would be from the linear generator.
Problems include ignition timing, and the 'air springs' generating heat. Here's a solution from Toyota:
Green Car Congress: Toyota Central R&D developing free-piston engine linear generator; envisioning multi-FPEG units for electric drive vehicles http://bioage.typepad.com/.a/6a00d83...9af6970b-450wi Quote:
In the 2006 EPA documents the efficiency of free piston engines was calculated to be 58%.
OMG, A FREAKIN TWO STROKE. YOU CAN'T POSSIBLY GET IT TO PASS EMISSIONS. A quote from DOE documents sent to me stating that a rotary engine (not wankel) could never be built that would pass emissions in the US. Google INNAS Chiron, direct hydraulic pressure free piston engine and a drive design with close to 3 times the regenerative efficiency of gas electric hybrids. So today, when proposed by Toyota, everything is copacetic. regards mech |
I like the opposed piston design, less heat loss to the head, well theres no head. Could have a genrenerative gas spring where waste exhaust heat is added near bdc.
I imagine we might see some microturbines and micro-generators with a fixed power output and much better efficiency (esp with cogen) i.e. ~%60 fuel to electric. I don't know if this is gonna make it into production. As an aside, it is hard to get %93 mechanical to electrical efficiency in a hydraulic pump at 800,000 rpm :D
https://www.academia.edu/5905748/MIC...RO_GAS_TURBINE |
Constant power turbine not a new idea:
An Electric Car That Hardly Needs Batteries - Businessweek http://articles.latimes.com/1997/nov...iness/fi-55325 https://www.youtube.com/watch?v=xG66JQmdMv8 http://forums.pelicanparts.com/uploa...1323296049.jpg Quote:
At 0:24 seconds—that thing is/was loud!
