List of ecomods automakers can use, ranked by cost/effectiveness
ABG posted an article with an interesting list of mods that new car makers are looking at to improve efficiency.
The interesting bit is they're ranked by cost and effectiveness. The figures were compiled by the U.S. NRC (national research council): Code:
SI Techs ...................... AVG Incremental Cost ... Avg Cost for |
Very interesting.
I did a bit of math, and here is what the report says the following technologies are worth MPG wise.
Code:
Low Viscosity Lubricants ...................... $6 .......... $12.00 ... 0.5% |
Driving style changes: 50% MPG improvement / $0 = infinite return per cost. :D
-soD |
What does
Conversion from SI to CI mean ? |
SI = spark ignition, CI = compression ignition (diesel).
Replacing a sedan with a smaller hatchback, or an SUV with a smaller wagon or minivan, is an item with NEGATIVE cost and positive return. The above mods are mostly cumulative with vehicle downsizing and driving style. It should be noted the above tables are based on cost to the consumer. If they're charging $6000 more for a full hybrid, they're making quite a bit more money. I bet "inflation to sidewall max" and "grille block" would be at the top of the list. I wonder where a variable grille block would land. |
I really don't understand how you could derive these costs. Things like these have to cost little to nothing when in the near (to the point of near unlawful) vertical monopoly that is a car industry. Take Fuji heavy industries, for example. They already own the machines required to manufacture car parts like this, and have enough money invested in their respective raw materials' futures, so they always get an agreeable price on the raw materials, and the cost of each part would therefore remain low and constant. |
...the current move toward SIDI (spark ignition direct injection) engines isn't shown, but typically yields about 7-11% FE increase.
I see a source for some wiki data!
We don't pay US $ 5900 (4650 EUR) more for a comparable diesel engine. Quote:
When building a smaller car, its weight will be less by default. |
Stoichiometric Gasoline Direct Injection (GDI) ? |
As such, they don't cost the claimed 5900 USD premium over gasoline. Usually there is a diesel-premium on the European market, as the extra cost to purchase one is offset by the lower FC and / or the lower diesel price, but it is far lower than that. |
