Old 12-10-2010, 07:13 AM   #1 (permalink)
3rd Gen prius wheel weight?
Hello everyone,
Im new here. My fiancee and I are looking into getting a 2011 3rd Gen Prius.
Im a honda fan thru and thru. Have done som road course racing and autox.
The first modification, I was thinking of, for the Prius would be to change the stock wheels to light weight forged alloy wheels.
My stock honda Fit sport wheels weigh approximately 17 lbs each. I used to use my Volk TE-37 forged aluminum wheels which are 17x8.5 but only weigh 13 lbs each.
I have retired them to storage and use 15x7 Wed Sport which weigh 10 lbs.
Now im using Civic HX wheels 14x5.5 and only weigh 8 lbs. They are my winter wheels.
So does anyone know how much the stock Prius wheels weigh?
I noticed online that some trim level Prius come with 17 inch wheels!!!! OMG that is a lot of spinning mass.
Old 12-10-2010, 12:20 PM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Welcome to the forum.
Normally I wouldn't recommend cross-posting, but in this case you might want to repost in the "hybrids" subforum.
Old 12-10-2010, 07:44 PM   #3 (permalink)
According to someone on PriusChat...
Using a very sensitive nitrous oxide scale I got 31.5lbs.
(That's the tire and rim)
Old 12-10-2010, 08:07 PM   #4 (permalink)
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
I looked up the tire weight for OE fitment, and the goodyear fuelmax tire is 19.x pounds. This was for the 3 trim level that also showed 2 other OE tires.
Autospeed article: adding a chin undertray to a 1st gen Prius MetroMPG Aerodynamics 20 03-18-2014 05:31 PM
Travel trailer opinions wanted dpero Aerodynamics 80 01-08-2011 07:48 PM
Gen III 2010 Prius Matt Herring Hybrids 3 08-30-2010 03:04 AM
Prius fatal accident rate bwilson4web Hybrids 22 02-05-2010 11:23 PM
Geo Metro 13 inch steel wheel weight MetroMPG EcoModding Central 8 06-25-2009 11:10 PM
