A little about my project
Ok, so here goes... I've grown to be disgusted by the high price of gas/ the horrible mileage of my current daily driver, a 98 chevy blazer (16 mpg)! And after several months of studying up, decided to do a 100% EV conversion! I looked around for a possible donor for quite some time, and finally was able to secure one in the form of a 96 dodge neon which had a blown engine. At this point, I've stripped it down... Removed everything from the engine compartment that wouldn't be used, dropped the exhaust, replaced all windshields/windows with lexan, removed seats and replaced with light weight racing buckets, removed hood fenders quarter panels trunk lid and bumpers and replaced all with fiberglass, replaced the wheels with lighter weight rims, and put disc brakes all the way around. At this point my neon is weighing in at just under 1400 lbs, so I'm off to a great start (I think)! Now I begin the hard (costly) part, I begin collecting the components to convert it to DC. When I'm finished, this car will be my daily to and from work car, and used for being out and about in town on my days off. I am planning on getting rid of the gas hog and purchasing a more economical car for long trips, but my Neon EV will see the most action. My round trip commute to and from work is 68 miles fairly flat for WV per day, and I'd like to have a little bit of extra in the batteries as a fail safe, is 80 miles per charge possible? I plan on using a warp9 motor, or at least something similar... Any suggestions as to batteries? I don't mind springing for LiFePo4 cells if necessary,and someone could point me in the direction of where to get them for the beat price. I was thinking maybe 96v at 200ah would suffice? As always any input/advice would be greatly appreciated!!!
Hi, welcome!
Can you make photo album of your project and give us a link? Unfortunatelu I cannot give you advice because I dont have much experience with EV's. Is it possible to charge at work? |
Well, your off to a very good start with that weight reduction effort. I have a converted MG Midget that you can see at www.electricmgmidget.com that has a 112 mile range and could be very similar to your build. I used 120 volts and 160AH batteries, so that is very close to your guess at what you'll need to get your required range. Be careful in picking the volts VS AH as that can change the way your car drives as far as acceleration. The total KWH will be more important to your range. I try to discuss my motor and battery trade offs at my site, so you will find that useful. I kept the transmision and clutch, which I highly recommend doing to get a good driving car. Please feel free to get in touch with me directly if you have questions. I'd be happy to help you in going through your design options.
I think you're pretty close to your 80 mile range. :thumbup:
Below is a range chart from the Leaf forums. At 60 mph the Leaf gets 82 miles of range. Your DIY setup while very similar to the Leaf likely isn't as efficient due to the DC vs AC drivetrain. I'm not sure what kind of efficiency hit you take here, but my guess would be around 5%. Of course you will gain some efficiency for having a lighter vehicle. I'm also not sure how much of a gain you'll see on the highway though. In town less weight will help a lot more though. If you keep the speed down a little you're golden. http://i565.photobucket.com/albums/s...tVersion7F.jpg |
These are the cells that I am looking at, mostly for price... hopefully they will serve their purpose well.
160Ah, 3C, 3.2V Model: BP-HZPP-160 10.0 x 2.24 x 10.4in |
I've never heard of that cell manufacturer. I have heard you can get calb cells for $1.2/ah which is the same price. They have comparable specifications and there are others using them so they're a bit more proven.
Sounds like a great project!
My advice is that you go as high with voltage as possible within your budget. The higher the voltage, the less efficiency is lost to heat in your cables and whatnot. You can go quite high before a Warp9 turns into molten lava - something like 192V is still within reason. Plus, when you want to have fun going fast, high voltage will put a giant smile on your face. Controllers do get quite pricey above 144V but many people say it is worth the investment. Keep searching the EV trading post for parts. [EV Tradin' post] - Electric Vehicle Classifieds You can register to get alerts emailed to you when something you are looking for goes up for sale. Best of luck! |
This is the place I heard of someone getting that price. He apparently bought 100 of the 100Ah cells. I got the info 2nd hand, so you're 3rd hand. :) CALIB POWER |
Generally speaking you want your vehicle at the max reasonable speed you want to travel to draw under 200amps, preferably near 100amps. Ideally with your pedal to the metal cruising at about 3500-4500rpms you should be at your top speed you want, have a gear or two below for mud and a gear above for special circumstances. Every EV I have dealt with runs most efficiently (in terms of power in power out) with the pedal at WOT. AC systems and DC systems become rather inefficient at low throttle positions, enough that on a lithium setup you are loosing at least 25% out the window on PWM if you drive in that region often with a typical controller. You normally still gain range because of better aero at low speed but its still worth knowing. Other factors such as using lead batteries is when amp draw and rate become more important than controller losses, lithium this isn't the case. So the most effient and lowest cost EV is typically the same car. Less volts, costs less, and is less to maintain, has more parts available off the shelf new and used, but also will have less performance but be taylored to drive a specific speed most of the time and do so most efficiently. Cheers Ryan |
I found your reply interesting. In particular your claim about 25% loss in efficiency when not operating at WOT. My controller, and I've seen others claim 98% efficiency. Since they use PWM to get that, I'm interested in why you think it is only 75% , not the 98%. I would agree that picking a gearing that allows for using one gear and eliminating transmission losses is a good idea. In my 4 speed transmission, the 4th speed is straight through, so It doesn't have losses due to gear friction, but I do have losses due to the transmission oil in any gear. I drive in 4th gear whenever I can. Since we're on the topic of efficiency I wanted point out that fast acceleration to a given speed doesn't use any more energy than getting there slower. The energy is the same, but the power required is higher. I haven't tried bringing this idea up yet because I thought it might cause some controversy. For electrics the only extra losses would be from I^2 R losses due to needing extra current, and the purcket effect which for Lithiums isn't very much. I don’t know how much the I^2 R losses are, so I’m going out on a limb as far as that is concerned. |
You need to take motor and controller as a single drivetrain unit... 98% efficiency motor and controller only occurs at WOT, below that it must be another number, AKA switching losses affect both the controller loss, motor losses and battery/conduction losses not just one or another. I was always taught to consider a DC ev drivetrain as being roughly 85% efficient overall, it goes up to 93-98% at wot (motor/controller/wires) But if it is 85% overall and it peaks at 93-98%, what happens if you are driving at low throttle below the average? Anyway I deal mostly with lead and forklift style DC motors but many of the AC controllers suffer the same as a DC controller when your throttle is under 50% Depending on switching speed you can easily loose 25% of power applied through the controller & motor to switching losses when throttle is "light", where that would occur would depend on voltage, rpm, and switching speed.. On my one EV (real world) 50amps at light throttle gets me to about 18mph and no faster without wind or hills, WOT I accellerate to 30mph and level out at about 65amps, the amount of energy difference is only around 30% (out of the battery) but the power generated is greatly different, the odd part is once I get up to speed, if I let off the gas slightly so I float around 50 amps my speed only decreases slightly and holds around 24mph, this is because field strength is higher so switching losses/motor losses end up being lower (higher throttle position to push 50amps whent he motor is spinning faster) There were composite maps of efficiency on the diyelectriccar forums of one example controller that had a very fast (efficient) switching speed at various throttle positions, even on his controller things were not as pretty getting below 50% throttle. The thing is an AC controller does not need to PWM until RPMs and power are quite low since timing can just be adjusted, so AC tends to be more efficient at lower loads but usually, though not always less efficient (a percentage or two) at wot as compared to a DC controller and good motor combo. All this said once you get to about 75% throttle most every controller & motor combo, even a terrible one gets over 90% efficiency, it is down on 50% or less that things get murky, especially at low RPMs. So in other words if you aren't running WOT or close to it, it isn't 98% unless you have an extremely efficient controller & motor I haven't encountered. I have never understood why people ignore the bottom 50% of the throttle in terms of efficiency. On my EV I only try to use that area when hypermiling because I can more or less drive WOT all day without speed worries. I have considered adding a large capacitor bank to improve my low speed efficiency but I am uncertain how much affect it would have, my controllers switch rather slowly Curtis 1204/1209 but aren't real bad, just not great. Ah well, But then again mine are old, low tech, slow and reliable. |
Thanks for the lengthy reply. I'll look into what you said about the controller. I have been assuming an 85% to 90 % efficiency for the motor, 10% loss in the drive train, and a couple of percent for the controller.
Normally most folks who have EVs never have so much voltage to end up in this region but you setup may be light enough and aero enough to get awefull close. Cheers Ryan |
