Little help with INJ signal, on a motorcycle
Hi there,
Im considering the MPGuino, but first i need to know if i can get the right INJ singal The bike is a Honda CBF125, with PGM-FI fuel injected by Keyhin. The thing is: im almost sure that is a wire pink/green the INJ signal, but i dont know how i should measure it. Voltimeter? + to wire, and - to ground (engine earth)? What values should i expect when accelerating? thank you a lot |
