Living in a Van Down by the River
Hi!
I participated in the forum while owning a 1996 Pontiac Firebird, then a 2002 Madza Protege5. I just bought a 2009 Chevy Express 2500, with a 4.8 L Gen IV V8 and 4L60E. It has 100k mi, part of a nearby municipality's fleet - it looks like it was babied. While I'm not expecting miracles, I'm going to do what I can make this a little less of a hog. I'd love the community's input! |
Paint Freak_Andy on the side? :)
Over-drive. or change the rear end ratio.
Tune. Econo cam. Narrower, taller, over-inflated tires and/or LRR tires. Lighter wheels. Aero mods. Boat tail, under-tray. Weight reduction. (not going to have that much impact) Alternator/accessory delete, under-drive, whatever. Block heater, grill block, warm air intake. Plug-in hybridize it? More importantly...will you be camperizing it? daily driver? work vehicle? Off-road beast? |
Part of me wishes I had sprung for a 2013 on the lot because by then they had a 6-speed trans and variable valve timing. That being said, while I don't necessarily care to break even on mods vs fuel-cost savings, it was hard to justify an extra $2k and +20k mi on the odo for those things, especially since I don't have a clear picture as to how much/often I'll actually use this thing. I might be inviting wiring-gremlins, but I'm seriously interested in the idea of a 6 speed manual conversion. Although my old Firebird was a Gen II small block (and a whole lot lighter), I quite liked the T56 it had. As for use, it's neither a daily driver or work vehicle. I'm a travel nurse, so my commute is potentially different every 12 weeks. It would best be described as a camper/weekender - I've never been one to off-road, so that's not much of a concern either. |
I do plan to spec-out some wheel & tire combos like you described, so when it's time to replace them that decision won't be rushed. Hopefully, before then, I'll have a better idea as to the vehicle's final weight and use-case by then as well. I'll probably look at tune, cam, and final drive after a few thousand miles' use. I feel as though I should approach it's final weight first, to get a better idea of how much I can get away with. As for weight - I'm going to start pricing out weight-savings options from day one. Since, sadly, the van as a camper will all but certainly end up weighing more than it does now - I'll be looking at weight-gain-avoided alongside lightweighting the vehicle in more typical ways. But yes, I agree, it's a lot harder to realize efficiency gains from lightweighting a vehicle of this size (rotational mass excluded). Thanks again for your input! |
https://ecomodder.com/forum/member-f...-1224-copy.jpg The headlight covers were design to make a bellmouth to the radiator opening, but your model has severely rounded front corners so it needn't apply. The swan-neck mirrors, air curtains and skirts and whatever that spoiler/Kammback/airfoil ring was intended to be may apply. |
I definitely plan to look into this further though! I've always preferred driving MT; If I were to optimize things with the auto, I'd have to teach myself all about torque-converter lockups, tune and/or mods to change shift points. It sounds interesting I would probably enjoy figuring all that stuff out, but at the end of the day I would still have an automatic transmission. |
-------- I think dealerships, (who are automakers' real customers), did a really good job selling Americans on automatics in the 20th century. More reasons for the car owner to come back to the dealer for services. A less cynical explanation may be with our 'lazy liters'/large displacement motors, it's flatter power-band meant it's less critical if you're in the optimal gear. Also, since they're generally revving lower, with deeper/lower-pitched intake and exhaust noise, I think it's less unpleasant. That's completely subjective, but my old Firebird sounded fantastic humming along at 1800 rpm on the highway. Driving smaller displacements engines at similar engine and road speeds, I appreciate good sound deadening lol. Another explanation may have to do with American car enthusiasts' preference for drag racing. Once you begin to modify a large V8, you're likely going to exceed the transmission's torque capacity. Once you get some good and bitey tires, you're probably going to ruin your rear differential. That gets expensive quickly - I think it's generally easier to find/build a beefy automatic. Nonetheless, I always try to get a manual transmission in my cars when I can. |
1 Attachment(s)
Well don't do what I did. In my campervan conversion I lifted my Astro 2 inches, installed oversized tires, and put a rack on top to hold solar panels and carry a raft. (Picture below from yesterday while I was lifting the rear another inch)
I ended up lighter after the conversion than at start. My Astro was a passenger van and the rear bench seats, carpet, and pad are heavy. I pulled the interior, insulated with double-bubble foil insulation, and put in a plywood floor as a base. I don't have a toilet or grey water tank in mine. For the next campervan which will be for full-time RVing I going to use a Nature's Head composting toilet so I don't need a black water tank. The biggest thing you can so is slow down. Even with the modifications for off-road use my Astro will still do 20 mpg on the highway at 65 mph. Increase that to 70 or 75 mph and the fuel economy plummets. I did a lot of research on expediter forums and there are people with your van getting 19 mpg fully loaded with 3 pallets running @ 65 mph. Run your tire pressures on the high side - that is an easy 1-2 mpg. (I air down to 30 psi when I go offroad to reduce punctures and that drops my mileage on the return trip) As to manuals - I'm a fan but not too sad that they are dying out. A reason for their demise you didn't mention is fuel economy. 5 to 6 speed manuals get lower fuel economy on the EPA tests than the 6 - 10 speed automatics. Attachment 30360 |
Haha, I bought a composting toilet before I even bought the van! It's a Separett, roughly comparable to the offering by Nature's Head in design and price. I agree that for more mixed use vehicles, it's smarter to have more gears like the late model 8 and 10 speed autos. But since I really won't tow/haul much, I'm thinking I'll have the most to gain from a manual because of fewer driveline/parasitic losses, and the ease of being able to P&G. But at the end of the day, if I do it it'll just be because I like a having a manual transmission. |
One of the reason I went with the Astro is because it is easy to lift. The front suspension, engine, and transmission in on a subframe that you can lift with just simple blocks. My lift kit was $225 and the same amount of lift on a full size van is about $2500. Before I lifted my Astro I was bottoming out the front bumper quite a bit offroad. Those commercial ladder racks do catch a lot of air. I suspect you would have no trouble finding someone willing to buy it if you decided to get rid of it permanently. I decided to make my own low-profile rack with aluminum 80/20. I'll be adding a 3rd solar panel for a total of 300 watts shortly and shortening my 80/20 to fit. After that it will get a front spoiler. If I didn't need to carry rafts and boats I would have just mounted the panels to the roof directly. |
I really don't know how I'm going to use the above roof space yet. Until then, it's coming off. But I can't lie: I'm seeing those roof rack mounted decks and I'm tempted!! :D |
I do know Ford brought over the AMT for their Focus starting around 2013. I've heard they've had to replace many while under warranty. I am curious if it said more about the manufacturing quality, or the way US residents tend to drive cars. All I know is that people I talk to here that have them really dislike the transmission. |
My parents owned a 1964 Rambler 770 station wagon. It had the E-stick transmission that declutched when you touched the shift lever.
There was a little ball-headed pin in the steering column that snapped off twice while I was driving it. They blamed my skill shifting until it happened to them, too. |
Even in the highly-conservative Brazil, now it's quite common to see not only long-haul semi trucks with an AMT. Even urban transit buses, which BTW are still often front-engined, may be fitted with an AMT as it seems easier for the fleet managers to get used to.
