Old 07-17-2008, 03:37 PM   #1 (permalink)
...in Training!
HyperMiler's Avatar
Wonton Mobile - '06 Kia Rio LX
90 day: 42.39 mpg (US)
Send a message via AIM to HyperMiler
What oil should I use?
My car is a 2006 Kia Rio LX with 26,500 miles on it. I drive about 24k miles a year, at least 75% being highway miles.
It says to use 5w20 oil in my manual. However, I heard that synthetic gets better gas mileage, is this true? Also, what's a good brand? I heard Amsoil is good. Should I stick with 5w20 or go down to 0w20 with the synthetic oil? Finally, how long should I go between oil changes?
Sorry for all the questions...
Thanks in advance!!
Old 07-17-2008, 04:04 PM   #2 (permalink)
Sandstone Princess - '99 Chevy Sububan LT
90 day: 21.04 mpg (US)
Joe - '02 Nissan sentra XE
90 day: 43.9 mpg (US)
Regal - '03 buick Regal LS
90 day: 33.85 mpg (US)
If you go synthetic, don't play around and just go with mobil1EP. It's not like mobil's or others plain synthetics. Mobil 1 Extended Performance
Old 07-17-2008, 04:22 PM   #3 (permalink)
Hyundai Accent - '01 Hyundai Accent
90 day: 38.4 mpg (US)
Gixer - '97 Suzuki GSXR600
90 day: 43.12 mpg (US)
Switching to synthetic may be a good idea, but it doesn't allow you to switch to a lighter weight. Stick with the lightest that the manual recommends.
Old 07-17-2008, 06:01 PM   #4 (permalink)
...in Training!
HyperMiler's Avatar
Thanks for the info!
Old 07-17-2008, 09:03 PM   #5 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Synthetic oil changes should go no less than 5,000 mile oil change intervals. Any sooner is a waste of money.
GeoMetroforum.com - got mpg?
Old 07-17-2008, 09:11 PM   #6 (permalink)
...in Training!
HyperMiler's Avatar
That's what I thought, thanks Johnny Mullet!
Old 07-17-2008, 10:03 PM   #7 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
if you had a car with a real oil pressure gauge then you would run the thinest oil that let you keep your oil pressure up high enough to keep your crank bearings suspended in their cushion of oil, without this gauge you can kind of guess by telling how soon it takes for your oil pressure light to come on after switching the engine off in a coast, in the winter mine holds pressure for almost 7 seconds with 0w 30 oil, in the summer it holds pressure for almost 2 seconds with 0w 30 and 3 or more with 10w30 synthetic, being a new engine that should be broken in, I would say 0w 20 might work as long as it doesn't cause any problems, if you aren't sure then don't do it, it's that simple, if you are willing to take responsibility to make sure everything is ok, then do it.
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-08-2014 11:22 PM
Pick Your Poison - Whose gas to buy? SVOboy General Efficiency Discussion 84 11-22-2010 10:19 PM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Alberta Oil Sands Gone4 The Lounge 8 02-19-2008 07:58 PM
Book report: The Last Oil Shock by David Strahan AndrewJ The Lounge 0 01-16-2008 11:55 PM
