The long road to Bonneville, goals are 40mpg useable pickup in the 150 club
This all started in 2013 when my cousin sugested theres a pile of steel and that I build one of my Ideas . It became the "Aero Tonto".
So thank you Brent for pushing me to just peek. Now my eyes can see. I was sponsored @Darco by Aerohead. Then we went to Bonneville to see the eye candy. I fell in love. And decided last minute to run. Knowing that my truck hits the governor at less than 100 and my tires are only rated for 106mph. I hit 87.14mph on the standing mile. @ 2500rpm . It took almost an hour to figur out what class I'd run in ,they finaly decided on T (time only open class). With a call to the rules people it was established that my Aero Tonto alone, any mod above the bed rail puts me in the UDT(Unlimited Diesel Truck)class. Full aero package less cap is MDT(Modified Diesel Truck. And 0 aero is DT(Diesel Truck) records for my size motor are; UDT 272.685MPH, MDT228.804MPH, DT215.091 MPH. The piece that confuse the inspectors is the rule specify 14500 GVW/race weight minimum in anything except for DT Stock 16-22.6mpg avg 18 3k mi Aero Tonto 18-29.3 avg 24 over 100k mi Not raging on those that do but 0% EOC (not safe) DWL (inclueds most of the conserve momentum tips. It just how you learn to drive when living in the mountains) Drive by Vav/boost /EGT gage its amasing what a 25°f change in EGT can do. This is an ambitious long turm multi step process. With self imposed restrictions. Truck must 1 be street legal 2. Be able to carrie 1Cord of Green Oak in the bed with all mods in place.(CDF definition is 3000lbs) 3. Tow 10k lbs 1k mi 4. Be returnable to stock ,except hood. 5. Sealed IP till after HP/aero adds up to 130 club Step 1. Aero package up to 40mpg. Stock tune(factory sealed macanical injection pump (IP)) 2 Custom Quickchange extreemliner differential (QC)this allows mixing and matching from 1.2:1 - 5.11:1 takes >15min to swap gears Carrie three sets of gear race, daily driver, tow heavy. This is custom because Winters the QC manufacturer has stated that the diff can handle my power/tork(could end up over 1500ftlb), however, not the weight. The QC only uses ford 9" axle/ berings I need a full floating axle to meat my restrictions.(weight) At this point I'll return to Bonneville. Qualify 130mph club, 150club. One theory is , with the right aero package its 1hp /1mph. So 160 is plausible if I get the aero right, and if I'm lucky 175+ to get to the big track,With a stock sealed IP 3 strip it down and run for an ABA test (sealed ) 4 reassemble A run 5 release the Kraken start turning the screws on the pump( tuneing for power) and see how far she will go with 300+HP, this is conservative number as this motor is capable of 400HP on the cheep at the expence of longevity. The costly part is making it reliable. 6 run the full aero +tune +street gears for improved mpg. Hopes are for 1-10%gain over aero/gear only Sorry no pictures the sight is not allowing at this time. To those that dont like WOT this is not a thred for you sorry context in too important. |
130-club
An otherwise 147-mph 2012 Mini Cooper S,with 181-hp,and an Iced down intercooler, just eked out 130-mph in the mile in 2012,due to the extra rolling resistance on the salt.
At 2730-pounds,that's basically 1-hp per 15-lbs.Power-to-weight is more important than any other factor in this 1-mile drag race. If the Dodge was 4,000 lb race weight,you'd need a minimum 267-hp available to squeeze 130 in the mile,qualifying for the 150 Club. -------------------------------------------------------------------------- I don't know anything about the 2-mile course. It's still a lot of acceleration.Aerodynamic horsepower would be 54% higher than at 130.Rolling resistance should be a linear function. *you'll need a roll cage *fire suppression system *V-Rated tires *current SFI fire suit *current SFI Hans device *current Snell-approved brain bucket That's $5,000 right there! ------------------------------------------------------------------------- If you could pull off the 150,then you'd be qualified to run the long course,which can be up to 12-miles long. You'd have to get your race license in 10-mph increments and the USFRA might let you use their roadster for that. Once you had your racing license for up to 180-mph,you could do bracketed handling runs in the truck,increasing speed incrementally until you'd run the truck for all she was worth. What a hoot! |
40 mpg
For the 776-mile tank,between Green River,Utah and Fernley,Nevada,I pulled the 250-miles of 65 mph travel out,indicating 36.9 mpg for the 55-mph portion.
If I throw in 4-mpg for the missing boat tail I'm knocking on 41-mpg,on unleaded Regular gas.If I throw Audi's 1.30-X TDI factor in,Spirit would be looking at 53.3 mpg. The Dodge isn't THAT bigger,nor much different in weight,so 40-mpg seems real doable,even with the firewood hauling capability.:thumbup: |
Ive been on the horn with Jim Dunn , the Truck and pickup class rules chairman ,to iorn out the details of, What calss.
For all truck classes except UDT and DS say, flat tonto cover that yeald no aero advantage are allowed ,but must not extend above the top of the bed. Theas are the 3 classes we came up with . He said that the 14500lbs min weight for the Mdt and udt classes is a missomer and that I wouldn't be held by that, only limitis 750cid If this changes the only class I fit with my Aero Tonto will be T, time. There is 1 more class that would alow our caps and that is DS Diesel streemliner @306.816 except "modified production bodies are forbidden " so maby shrink wraping it bumper to bumper may qualify . 87.14 was a rpm limit of my 2.4495 final gear(stock trans .69×3.55 rear end) and my refusal to brake the seals on my factory sealed injection pump. To raise the governor to 3500 or 4200rpm tell after 40mpg. 3500rpm =134mph 4200rpm =161mph. Without supporting modifications 4200 is not achievable. Stock lift pump bairly handles the stock motor lucky me it failed monday so the variable displacement piston pump is going in place of the diaphragm that came out. This is a reduced pressure high volume pump from the 2nd gen Cummins 94-98. Gears, aero package and safty will be my focus for now. |
You'd need the 60 LB valve springs to support the higher RPM, but those are easy to do.
I've done governor spring kits many times on P-pumps. If we could find the parts to convert yours to a P-pump, it is a bit easier to make big power. I even have a spare rebuilt 215 pump, already set for 3500 RPM on the springs. The trouble is, different injectors, lines, and timing set. It is a big job. |
Good luck! Are you planning for 2018?
I was driven to Bonneville two years ago, and I told my son and his friend Nick (a manager at Boeing) I would get myself there next year and be on a pit crew in 2-5 years. Last year I watched Nick do a 164mph run on his Ducati. This year he drove someone else's motorcycle at the 14000ft salt flat in Bolivia. I'm hoping I can get him for a driver. They confirm my reservation number for an Arcimoto FUV comes up in 2nd quarter 2018. I can cover the base price (bye bye Superbeetle) and I'm hoping they see the logic in sponsoring a Fun Utility Vehicle run at America's Playground. Maybe they can sponsor me to the extent of doors. :) I'm thinking stock, except for replacing the 145-65/15s with 155-50'19s (from the BMW i3) for longer legged gearing, and a two foot boat tail. |
Racing is tough.
Then, there's Bonneville. |
The first year I was there, we met a guy from Montana who'd gotten a $1000 Dodge pickup running, thrown his toolbox and motorcycle in the back and headed to Bonneville. Assuming he'd a luck into a pit crew once he got there.
My son's friend volunteered and drove the chase truck for his run. After the motorcycle took off, he followed toward the horizon and promptly lost him, and drove right past. IIRC they had to send another truck after the chase truck. It's like another world. |
150 club 2point(pt) cage to hold the shoulder belts of the required 5/6 pt harness at the proper hight. 175 full cage. Race capable fire suppression@175 +( they Overlook the fire extinguisher in the 130 and 150 because the Marine style mounts just turned that two and a half pound fire extinguisher into a 5 lb chunk of aluminum hit me/you upside the head) Nomex 150+ Hans 175+ Current helmet check. Dreem Big Chisel Down To Reality |
I've talked to the head of marketing at Arcimoto about them sponsoring a vehicle at Bonneville. He wasn't too excited. I was trying to convince him to subject one of their FUVs to the salt environment, so it wouldn't have to be mine. Fording creeks of brine didn't do my Superbeetle any good at all.
Any prognosis on the Salt yet this year? Sometimes it doesn't dry out. I've been thinking El Mirage instead, of only because of the corrosion. I don't know how those bare-metal Model T do it. |
El Mirage would be great for our purposes at EM. Our speeds are just not super high and they have about 1 mile to a mile and a half of useful track. I would love to participate in any good project as part of a support team. |
gear
Kirky aluminum racing seat Simpson 5-way harness I've got 2-firesuits but we'll have to check on specs and size 7-1/4'' Bell Star helmet Snell- approved large Simpson racing gloves fire retardant underwear fire retardant balaclava 10-1/2'' Simpson racing shoes/socks 3-parachutes if those can be helpful Let me know!:) |
An FUV would be hard pressed to top 100mph. |
Choices for rubber gears...
1 Attachment(s)
Most "H" or fasters speed rated tires eather have no load capacity or are 28" or smaller or10-30"wide drag rears.
To day I've found some options 32.18"D 235/55r22 (104w) 1984lbs 168mph $154 usd 31.41"D 275/25r26 (98w) 1653lbs 168mph $215 sud 30.04"D 255/50R20 (109Y) 2271lbs 186mph http://ecomodder.com/forum/attachmen...1&d=1527834325 B stock rpm +.20 od + 3.08 gear swap. C as above + 3500 gov spring. Now comes the question witch one will have the best coefficient of rolling resistance? What effect will the different wheel sizes have? Options 1 is 140.5 good for 130club +150club rated option 2 is 137. 2mph@100% transfer of rpm. (The 518 non lockup torque converter has demonstrated a 5% loss of RPM) Option 3 131.2mph this option will requires the 3500rp. Gov spring for the 130 club . And will be useable allthe way to 175 + to qualify for the long course. |
R-R
When I ran,a 147-mph Mini Cooper would only do 129-mph because of damp salt track conditions. 136-mph Mazda-3s could only do 118-mph. The efficiency of the tires may be essentially destroyed if you have any rain. Question,if you do 130,will they let you turn around and run the 2-mile 150 course? With only 2-miles to hit 150,you might have to gear it for just over 150 and hope to hit it. If so,you'd know a lot more about her performance under real track conditions,which would help you sort out gearing for the final assault. Are there any online computers for top speed at a given set of parameters? |
calculators
Top Speed Calculator Car Speed Calculator james |
calculator
Something I've never investigated,was a calculator offered by HOT ROD Magazine in the 1950s,60s. They were able to tell you your distance to top speed,which I've never seen before.Since the trucks load varies the entire length of the run,the calculation has to deal with all the transient dynamics,combining the calculus of the R-R coincidentally with the aero,matched with power available in each gear as you swim through the gears. It's a very complex relationship. Every time I go to the PATE Swap Meet I ask about this computer and the guys just roll their eyes back in their heads. I suspect that folks like George Poteet have access to this sort of thing.:p |
Gear vs speed chart found.
1 Attachment(s)
Found a good one.
gear/tier size/transmission calculators by 100 rpm increments Now to get expressed as a graph with the torque hp curves matched for each gear . Had Gran Turismo 3 in Iraq when you upgraded the car to the full customers customizable transmission you could actually monkey with each gears individual numerical value and was a nice graphic I guess I could hand plot all this Results fom link https://ecomodder.com/forum/attachme...1&d=1534110331 I ran the #'s out to 4200 as that is the $$$ red line. With the 3500 governor spring kit 135 @100% transfer is possible with a 31.7(stock size) 3.55 :1 (stock) 155mph @3500 with3.00. Take the 6% diminstrated losses (possible warn 2500 governor spring contribution.) And that is 126.9 , 145.7 respectively |
Don't wanna repost this whole thing, BUT, paste your data into excel and it will do graphs easy peasy
acceleration
I'm still thinking that we need an acceleration calculator.
If you watch 'World's Fastest Indian' you'll see Burt Munro dropping a rotary slide rule computer into his travel bag as he readies himself for the trip to Bonneville. I suspect that he had the HOT ROD calculator. To be able to predict your trap speed at the mile and two-mile,the equation must handle: *total mass *available horsepower along the total rpm range between shifts *gearing in all gears *polar moment of inertia for all rotating masses (gears,shafts,bearings,wheels,tires,etc.) *rolling force coefficient of the tires (no one has ever published the range of RR which cab occur on the salt,for the range of salt conditions which can exist on a given day *aerodynamic drag index *local air density at time of run (you can get this from Rick Gold@ at his racing fuel trailer on race day,with updates every hour or so) There's a lot of differential equations which must be solved simultaneously to calculate what you could expect.(a graduate student in mathematics would be your friend):) |
There's a way to calculate air density that I used to do when I flew because it is bad juju to take off from a too short runway. However in the enjoined 20 or so years I have forgotten it.
---- YouTube can be good . Gale Banks did a good presentation on Manifold Air Density MAD and how that has affected how he chases power versus others . I asked the channel if thay had access to the Hot Rod Calculator There response Quote:
--- MAD is one of my reasons why I am devloping a temperature controlled grill block referencing IC Nd engine coolent temperature. Cheep simple servo automated grill block active aero deployment. (Link). With additional blockages on other components that will open independently based on that components individual need. EG transmission cooler. this truck has a technical service bulletin advising not to drive the truck in overdrive below - 5F, this causes the viscosity to get to high in the air to liquid transmission cooler(aka it freezes) causing a restriction in the cooling circuit end result is' a burned-up overheated transmission, failure mode too cold. So I make shure that is blocked in winter( doesn't get hot enough to run without it covered in overdrive for two to three months where I live). --- Quote:
Should ought to be excel apps. Or equivelants. I have one in my note 9, linux machine, and galaxy 3. Preloaded, Of course they all work differently, duh.
I thought the trip to the site for altitude was difficult/convoluted, which was why I suggested the airplane solution. Now I recall I used a whiz wheel. |
https://docs.google.com |
The question is how to display tables as in Permalink #18?
It seems there was some discussion here about that I can't find. Seems Xist was involved. My thought would be Markdown. Write plain text, pipe it though the HTML formatter (local or online) and paste the result. https://github.com/adam-p/markdown-h...atsheet#tables |
Try this link: https://www.gribble.org/cycling/air_density.html
1 Attachment(s)
https://ecomodder.com/forum/attachme...1&d=1534109831
49k size is too big to insert spreadsheet so a croped screen shot will have to reprezent 3hrs of fighting with my device... I'll replace the above copy paste |
calculations
I found my paperback book on automotive mathematics.
The book has only an approximation calculation for 1/4-mile time and speed (within 4% accuracy for an example problem given). This won't help us. The book listed some commercial computer programs available at a price,but none of them were germane to Bonneville.:( |
2 Attachment(s)
Spent an hour on the dyno fighting with the transmission to get these images for you and of course me. 3-4 down shiftting @ full power.
You can see when the Governor starts to Defuel at 2000 RPM, and horsepower drops off. https://ecomodder.com/forum/attachme...1&d=1536541168 Hence the squiggles on the simulated 1/4mi. from 6-10 sec. https://ecomodder.com/forum/attachme...1&d=1536541168 Go go gadget auto rotate. |
130-mph
I spent some time thinking about the 130-Club.
*whatever the all-up race weight of truck is,with you inside,divide that by 13.336 to get your required horsepower,to get you 130 mph in one mile. *If you're gonna start with 130,then you need to select an H-rated tire,so we can get a circumference. *The surface velocity of the tread (11,400 feet/per minute),divided by the circumference will tell you your axle rpm. -------------------------------------------------------------------------- *We need the engine's redline rpm. *At redline,whatever your top transmission gear is,it's ratio will determine the output shaft/driveshaft rpm. -------------------------------------------------------------------------- *between the driveshaft rpm and the axle rpm,this will determine your quick-change ring and pinion ratio to have you at redline as you exit the one-mile trap at 130. -------------------------------------------------------------------------- *If you're gonna turn around and try for the 150,we've gotta start all over. - you'll need V-rated tires and their circumference. - the tires will be spinning at 13,200 surface feet per minute. - with the new circumference we can calculate the axle rpm. - the engine,again,will be at redline rpm. - top gear will establish the driveshaft rpm. - From this you can select your ring and pinion. -------------------------------------------------------------------------- *I don't know what horsepower is needed for 13,200 FPM in 10,560-feet. *the rolling resistance for V-rated tires is higher than for H-rated,so we'd need some more horsepower just for these tires. *aerodynamic power required will be 33% higher. * If you're going for 'time' you can streamline all you want. * If you're going for a record,you'll be severely limited on aero,and will have to make it up with more horsepower. -------------------------------------------------------------------------- *If we had the horsepower and total race weight for the 150-mph Karmann Ghia LSR car,we'd have a power-to-weight ratio necessary for 150 in the 2-mile!;) |
Dodge
blue?
It may be the only VW to go 150-mph.He was out there in 2012. |
The blue one turned 146mph.
http://www.myrideisme.com/Blog/wp-co...17-300x199.jpg Larry's Old Volks Home Ghia Land Speed Racer | MyRideisMe.com |
Larry's
calculator
Couldn't find any specifics on Larry's Ghia,but I found this:
RSR Aero-horsepower Calculator-RB Racing It's at the end of the 'document.' Plug in drag coefficient Frontal area Weight Speed and hit the button,for required horsepower and aero horsepower loss is also provided ------------------------------------------------------------------------- I did it for Spirit and it gave me 128-mph,at a discounted 147.17 horsepower. It's out ahead of nothing -------------------------------------------------------------------------- I threw some numbers in for Gumby's Dodge: Cd 0.45 36.9 sq-ft 4,000-lbs 130-mph = 298.82-horsepower (close to my Mini Cooper-based estimate) ------------------------------------------------------------------------- With same specs and 150-mph = 453.64-horsepower ------------------------------------------------------------------------ If 'Tonto' was slicked down to Spirit's 2012 drag coefficient he'd need only 281.4-horsepower for 150-mph.But they'd only let him do it for time,not a record. |
There ya go! That's what you were hoping the yellow Ghia might lead to. :thumbup:
Was hoping to achieve 1mph per Hp, but almost 2mph per HP stock???
1 Attachment(s)
Sounds promising tuning limits for my injection pump is 350Hp with minimal compromise as this only 50 above the original designed. 400 cuts life span dramatically. Swap to a P7100 like Skyjing has offered7-800Hp.
So its doable with a stock motor and a cupola bolt ons. Power to speed ?? I was hoping for 1: 1 HP:MPH dyno said ~50hp /70Tq at gov limit 2500/92.5 mph (I should have put 4th gear on a togle switch, dyno had same truble I had at Bonneville downshifting .) 1:1.85 hp:mph . The page with the correction factor said uncorrected 148hp 396tq was the best it could muster @5,950' 85°f 175hp 491tq with correction factor(lab conditions eg sea level, 25c 77f ect ect). There trying to find the corresponding graph for me. The one they gave me and I posted shows 115hp 309tq . To the ground . The 2nd one 1/4mi with several down shifts peaked at 95HP 1/2 way through 3rd gear fell off (this is very pronounced on steeper on ramps) made the 3-4 shift droping to ~ 40-45 hp then peeking agen followed by 3 4-3 down shifts. 1st gear is the only gear thar duse not show the defuel start at 2000rpm The torque curve shows the tq to the ground. Including the amplification from the gear sets, the shock load torque of the 1-2 shift is about 470 lb droping from 83to 25hp as the motor slows from 2500 to 1200. ------ 300hp will require more than just turning the screws. Planning stages Quick change rear. If i gear for peak power insted of peek gov my target will be at 2000rpm Trans Turbocharger I'm looking at a Borgwarner S362SX E with. 88AR wast gated.(I like how they have both volutes wastegated individually on a single actuator) set to 30psi. (Head bolt / valve spring safe limit) sitting on top of a BD diverter valve which will turn this into a .44 air ratio below 12 PSI this should improve my drivability around town but leave the top-end open for my Bonneville aspirations this turbo will support 91lbs/min (10 hp/lb flywheel 7hp/lbto the ground) 500hp in excess of what my injection pump is capable of. Option 2 https://ecomodder.com/forum/attachme...1&d=1538118479 SwitchbladeTurbothis option is a spin-off of a Variable geometry turbo . It also diverts the air at the nozzle end of the turbine housing with a shutter that moves out to expose more of the turbine wheel as boost builds. And injectors |
nice meetup with Gumby79
Gumby's been in the area and up to shenanigans for awhile,and was able to get over for a meet-up on one of his days off.
We got to spend a long day together,pouring over details of the Bonneville project. He continues to push steady on the Dodge, and with the SCTA rulebook,has all the critical info. he'll need to satisfy the safety requirements for an attempt on a land speed record.Pretty cool! We did some tuft-testing and captured some stills and video,to sort out aft-body flow he was curious about. The truck pulls strong.Acceleration is impressive.It will be fun to watch the project evolve.:):thumbup: We wrangled some pretty okay Mexican food too!;) |
