Looking for a 12v A/C or low watt 110V unit
Hey all,
I am looking for a 12v or low watt 110v Air Conditioning unit for car passenger compartment use. If 110v it has to be below 150 watts. Any idea's? |
check out these units from swampy, have one on my boat and it works fine. it will not cool down the car interior but it will cool you down if you direct the cold air flow at yourself, AKA from the passenger seat.
!MightyKool Personal Coolers by Swampy |
Thanks for the suggestion but I am looking for an a/c unit not a swamp cooler. The swamp cooler would raise the ambient humidity in the car too high causing musty smells or worse, mold and mildew.
However, this idea might be feasable in arid areas like AZ, NM and NV. |
What do you guys think about something like this? According to an online BTU calculator the Ford Escape needs about 3000 BTU for comfort. This unit is 4400 BTU so I figure its a nice safety margin. Do you guys think something like this would be better than running the ICE driven A/C?
DC Airco type 4400 is designed and used for cooling small cabs, and sleeper cabs of (EU) trucks. DC 4400 is a small lightweight dc air conditioner introduced in 1998, and modified in 2003. DC 4400 12 volt DC 4400 24 volt Cooling capacity 1300 Watt – 4400 BTU 1400 Watt – 4760 BTU Power consumption 360 Watt 30A 360 Watt 15A Size mm Size inches 700 W x 920 D x 265 H 27,5W x 36,3 D x 10,5 H 700 W x 920D x 265 H 27,5W x 36,3 D x 10,5 H Weight 30kg / 66 lbs 30 kg / 66 lbs Max. outdoor ambient 40 ºC / 104 ºF 40 ºC / 104 ºF Low voltage settings (Unit will shut down if there is a low voltage) 12 VDC = 10,5 volt 24 VDC = 21,5 volt Restart settings (If there was a low voltage the unit will restart at) 12 VDC = 12,6 volt 24 VDC = 25,2 volt High pressure switch 24 bar 24 bar Low pressure switch 2 bar 2 bar Safety switches Max. temperature compressor and motor Max. temperature compressor and motor dc 4400 - dc powered air conditioners |
