Looking into a kill switch
After experimenting will engine-off coasting for the first time tonight, I'm considering installing a kill switch and start switch. I read several threads on these and from what I've read, you can kill the ignition, injectors, or fuel pump. Which of these is best? I don't want to leave unburned gas in the cylinders, or hurt the fuel pump. My vehicle is a 93 Dodge Shadow and my last tank averaged 24mpg city. A kill switch seems like the next necessary step to boosting my mpg. Any advice? Thanks.
bkruger -
Welcome to EM! I checked your car. Because it's a manual, you can probably do the kill switch first and use bump-starts at first. You can always use the key or install the start switch second. My opinion is that different drivetrains have different "best" solutions. I know that for my Saturn, intercepting the fuel injector fuse will work, but I haven't got around to it (no excuse). CarloSW2 |
It seems there is no diagram for my fuse box anywhere. Is there an easy way to tell which fuse is for the fuel injectors?
bkruger -
Here is one clue : WikiAnswers - Where is the fuel pump relay on a 1993 Dodge Shadow Quote:
More good stuff here : WikiAnswers - Dodge Shadow Questions including "Where is the heater blower motor in a 1988 4 cyl Dodge Shadow" CarloSW2 |
I've looked all through the manual and a Chilton manual. The main fuse box is only for lighting, radio, etc. Under the hood, there are 5 or so black boxes, with wires that runn all over the engine bay. I'm assuming this is ignition, injection, etc. I'l post pictures tomorrow unless someone with a similar model can tell me which one it is or a good way to put in a switch. I brought a 12v 20a switch. Is that sufficient?
