Looking for a low battery voltage switch
I'm looking for a switch that monitors battery voltage. At a set voltage the switch would trigger a LED or relay. Anyone have any ideas on where I could get something like that? I know autospeed has one but I'm really not looking to order something from Australia.
I can confirm that getting something from Autospeed can take a while. My order was shipped via airmail 11 days ago. Must have been shipped in a Beaver.
A simple comparator circuit is all you need.
1 Attachment(s)
Daox -
Here's one : Universal Voltage Switch http://ecomodder.com/forum/attachmen...7&d=1227234561 Quote:
CarloSW2 |
Yeah, I know autospeed carries two versions of the voltage switch. I like the one I posted more because its all solid state construction and thus I don't have to worry about the relay ever dying. Also, I just would like to find a place in the US that has this sort of thing. Someone has to have something like it on this side of the pond.
NiHaoMike, I know I need a voltage comparator and that it would be a relatively simple circuit. However, I don't know enough about electronics to build one myself. The problem being that the reference voltage will vary. Unfortunately, I don't even know enough to look at a circuit and know if this problem has been solved. Lastly, I'm willing to pay a bit (not a ton) just to have it premade so as to save me the time and hassle. If you have any suggestions, or a diagram that would be great. |
Use a zener diode as a reference.
