looking for a thread on a good engine/block heater install for a 2000 TDI Beetle
Hello everyone. After spending a couple of hours searching around for a thread on installing a block/engine heater for a TDI i decided to just ask! If you can add or point me in the right direction, that would be most appreciated! :{)
DEFA sells heaters either installed in the block or a heater you install in the radiator hoses
the TDI engine is very widespread.
