lower engine load better for MPG, torque converter to blame?
My car allows me to accelerate with a locked up torque converter above 40mph with approximately 50-60% engine load at 1800rpm according to my scangauge. However below 40mph the torque converter is always unlocked or slipping (unless decelerating) so i havent noticed improvement with lower load acceleration. But for above 40mph every test i did shows locked acceleration at low loads is better than unlocked or slipping TQ at 80% plus loads. However instruments are not always accurate and i was just wondering what other people with auto transmissions think about this? Are torque converters the bigger problem compared to engine pumping loss associated with smaller throttle opening? Someone told me my car isnt subjected to traditional pumping losses because of variable valve lift system.
Get above lock speed with high load and stay above that speed. Besides we all know high load accel is best NOT low load.
with the torque converter fully unlocked my engine speed jumps to around 3000-3500rpm under load. At 3500rpm my ECU enriches the mixture. after some experimenting i managed to trick the TCU to keep the TQ locked using the throttle while increasing engine load to about ~95% at 1500rpm. you just have to slowly open the throttle, something to do with the drive by wire system. if you just step on the throttle (even if your only apply a bit of throttle) the torque convert will start slipping and RPMS jump. I found 1500rpm (TQ locked) and ~95% engine loads to give me best results but if anyone thinks i can improve on this to reach my 30mpg city goal please let me know.
Exactly why nobody here likes automatics. If the converter is unlocked any additional load just revs the engine higher. Personally, I accelerate moderately in first to about 15mph/2200rpm, let it shift to 2nd then get on it at high load and reach 40+/3800rpm and stay in lockup the rest of the way up.
the Jetta is DSG = no torque converter
the jetta hybrid is DSG
so there is no torque converter like is used in an automatic and will easily exceed 30mpg the jetta has a "glide" function where the drivetrain is disengaged from the engine for a "Power on coast" type of function the subaru ? can be tricked (as you have discovered) as rate of change in TPS value is a primary input to unlock the torque converter the only real fix to to replace the car with an automatic trans to one with a manual trans |
Mod to make it easier to keep a car in lean burn:
AutoSpeed - Giving the Insight a Good Driver Something similar might help keep the TC locked. |
