Lower rolling resistance: space saver spare tire donuts @70 psi, or RE92's @ 51 psi?
http://forkenswift.com/album/8-spare-vs-re92.jpg
Just for fun: what do you think would win a slow speed coast-down test, all else being equal:
For kicks, I also threw the spare tires into the shoot-out, testing at both 51 & 70 psi (sidewall says: "inflate to 60 psi"). Why? Because these wee tires seem to regularly find their way into discussions about RR, wheel/tire aero & weight... sometimes in a speculative, hopeful way. I will say this: I was surprised. Will post the details/results tomorrow! http://forkenswift.com/album/8-spare...angles-800.jpg |
I'm going with the Potenzas for a few reasons.
I know that tire pressure increases help rr with diminishing returns, and 51 is already pretty high. Secondly, I think CapriRacer said that wider can be better for rr: Barry's Tire Tech, rolling resistance part 2 I'm also assuming that the donut spare is built heavy-duty, and that you won't be going fast enough for the improved aero of the skinnier tire to matter much. But now you got me curious. |
...I'm gonna bet the spare (doughnut) wheel probably has better aerodynamics than the stock "full" wheels.
those are 5 bolt wheels... so what is the vehicle? without knowing the weight of the vehicle it's hard to say.
(EDIT: note from Darin - I changed the photo in the first post to one of the actual car - before, it was just a random one I grabbed.) |
I just grabbed that image to illustrate. The vehicle was the ForkenSwift (Geo Metro), 2070 lbs.
And the test was low speed: didn't quite reach 10 km/h / 6 mph, so aero can be safely ignored. |
...I'm not a Policeman, but I voted for the 'doughnuts' (wink,wink).
...DUNKIN' doughnuts, please. |
I would say the donuts. If you put there 70 PSI they will contact the road only on the centre. Usually they are already so round that the contact area is very small anyway.
A big part of rolling resistance is tire deflection, or the size of the flat patch on the pavement, that is why it is possible for some wider tires to be lower rolling resistance then a narrower tire, an example of this is on my bicycle, I'm a big guy and my 1 1/8" wide high pressure racing tires roll with just as much resistance at 100psi as my 2" wide bicycle tires do at 80psi because both tires need to hold my weight up and a wider flat spot ends up being less of a hill to overcome, at some point of course going wider is not going to give any gains.
I vote for the RE92s.
Well, to cut the suspense...
The donuts were by far the worst performing out of 7 sets of tires I tested on the weekend! I was not expecting this. (Maybe, like some others, I was hoping those strange looking little donuts would have mystical properties...) They fell short of even my crappy old Walmart snow tires, which don't roll worth crud. I compared 7 different sets of tires at 51 PSI, and then boosted the donuts up to 70 for a second set of runs to give them another chance - they still came in last. The RE92's came in first. At some point I'll post the details. Later, though! It's Turkey Day weekend in Canada. And lovely outside. I'm going bike riding with my nephew. |
To help visualize just HOW bad the donuts were compared to the RE92's (which henceforth shall be known as the Tires Of The Gods), a photo with the car at actual starting & stopping points:
http://forkenswift.com/album/8-re92-...t-panorama.jpg I used a big parking lot that's empty on weekends. The starting "hill" isn't huge - maybe a couple of feet elevation change where the entrance/exit goes up to meet the road grade. But it was enough of a slope that the car rolled ...
...the numbers don't lie...but, the people cussing & discussing them might (ha,ha)
Is it possible that the spares are bias-ply instead of radial? That would help to explain their poor performance.
I drove the tempo on 4 donuts once while refinishing the stock wheels. I did have the distinct impression that rr and ride were poor vs stock- unfortunately, did no roll test tho'.
no cussing this is the truth right here just watch the vid i run these tires alll year around and no problems and i my self have calculated 4 mpg inrease and able to coste almost twice as long in neutral yes youn are right watch this vid, this tells the truth |
I wonder how much of a difference it makes between 51 and 60psi on the RE92'S? I run 60psi on my RE92'S so, yea. (58 cold)
hysteresis losses
The donuts wear very quickly and suggest high hysteresis losses,whereas the 92's are formulated for low hysteresis,giving back energy after deformation of each tread block element.
When I bought 5 doughnut spares from a Altima I tried them out on my Metro before I put the Continental eco tires on. Results similar to what you had, that's why I picked the RE92's.
