Lowering Prius - raked or level?
I am going to lower my new Prius Plug In and I can choose between springs that keep the car level or ones that create a slight rake.
The TRD springs that come on special package Prius will lower the car approx. 1" all around. H&R springs will create a more raked look and lower the car approx. 1.2" front and .75" in the rear. My question is which drop is better aerodynamically speaking? The raked stance is good for downforce and may reduce the amount of air going under the car while accelerating aiding the evacuation of air out of the rear. The extra downforce scares me though. Wouldn't that increase rolling resistance? The level stance is how Toyota set up the car and how the Performance Package comes but with the extra weight of the Plug In, I am worried that the rear may go lower which would create a very slight reverse rake or at least stay level. The bottom of the Prius is pretty clean so I am not sure how much lowering will help or hurt. |
there is a science to it. Not sure though if it applies here.
Back in the 70-80s one of the mags eco-ed a muscle car....maybe the duster....found that dropping the front nose really helped. maybe 2mpg But you have to remember, there was NO slant on the front of those cars like there are today. My bet is that the slight is already in the design. with that said, I dropped the Q45 about 1 inch in the fron and saw a slight improvement in mpg. (your'll have to search my posts) also, smashed the IMPUL body kit becuse of the 1" drop. (again search my thraeds) Finally, If there is ANY deterioration in the ride quality, I wouldnt do it. I had put in An aftermarket spring kit....took them off after about 5k miles. And the Q45 has electronic suspesion! I just was not going to put up with a crappy ride for the looks. |
That is hard to say. If I had to guess, I'd say level is best.
And yes, more downforce = more drag. And lowering the car doesn't necessarily mean lower drag. It might constrict the air flow under the car, and increase the drag. Is that your Prius in your avatar? If so, you could lower drag a fair bit with smooth wheel covers. |
One inch on a Prius is like having 4 adults in the car so I wouldn't stress too much about it. I would go with the TRD springs as they tend to be the best spring rate balance daily driver/performance as Toyota can back their install with warranty and will most likely have the least impact on the life of the strut shock absorber after stock.
Thanks!
The avatar picture is my old Prius. The new one has the OE Plug In wheels which are a little more aerodynamic looking. The worry with the TRD springs is they are designed for the regular Prius which has a smaller battery and weighs about 100lbs less. This may create a little butt sag. Since I have never seen a Plug In with the TRDs in person I cannot say for certain but some of the pictures I've seen are worrisome. With the H&Rs I can get them for $200 installed through a friend. This is more of a mental exercise than anything. The relatively clean body of the Prius makes the idea of lowering for better aero a little confusing because of what Neil stated. Lowering a car with a very clean underside may create drag. |
http://i1047.photobucket.com/albums/...ps41c79db6.jpg http://i1047.photobucket.com/albums/...ps5ac627f9.jpg http://i1047.photobucket.com/albums/...psc592a497.jpg http://i1047.photobucket.com/albums/...ps66a77d40.jpg http://i1047.photobucket.com/albums/...psd45c6486.jpg |
Wheel skirts would a much less drag from the wheel wells; not just a little.
Besides, I'm not sure F8L will want to go put home-made wheel skirts on his new car:eek: |
Why not?????
Fourth: rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938 |
