Old 06-09-2008, 11:37 AM   #1 (permalink)
Polymer - '89 Honda Civic Hatch Std 4 speed
Woodstock - '69 MG Midget 1275
Nekobus - '06 Scion xB
One. Step. Further.
Last year, I bought an '86 Toyota pickup for another project that may or may not ever materialize... http://images.google.com/images?q=locost
Then, after reading this site and others, I was rather inspired by Phil Knox's '94 Toyota Pickup.
So, I've come up with my own design, to be created with laminated wood beams bolted onto the truck, and a canvas sheet, plastic or aluminum slung between the curved beams
Here are two designs, one noticably more aggressive than the other.
I have no qualms about sawing the rear end off this truck. It's made of rust anyway (but the engine is in great shape).
Thoughts, comments?
Old 06-09-2008, 12:06 PM   #2 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
personally i think the first is better than the second, the angle of the rear is quite important, i believe up to 11° the air will stay attached but beyond that it will start to separate... wich is why certain cars with a low Cd such as the prius or the audi a2 have a pretty high rear, to not exeed this angle... the longer the car the lower you can have the rear. from the look of if the top drawing has a better angle that the lower one.
if you are going to cut into the body, try sloping in the side behind the wheels. the top profile is just as important as the side profile.
but don't take my word for it, as ther's people with more knowledge on the subject here
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 06-09-2008, 12:13 PM   #3 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Honda Civic Sedan LX
90 day: 35.68 mpg (US)
Arrow
That looks really good, MilleniumTree. Are you going to put a hatch so you can still use the bed? Because if you aren't going to get any benefit of a bed, why have a truck?
I suppose you already have the truck ... so why not?
I think rear visibility is going to be the hardest to do well.
I like the white truck above it ... but why didn't they take the rear wheel skirts down any further to meet the bottom of the bodywork?
--- Bror Jace
Old 06-09-2008, 12:21 PM   #4 (permalink)
Wow. I feel like I've just stepped into the mind of a mid-80s Japanese engineer.
This is a re-design with exactly 11 degrees.
This is on the long-bed pickup. I'm sure the short-bed would be a little different.
Old 06-09-2008, 12:30 PM   #5 (permalink)
Yeah, I would probably put a hatch in. I really only intend to use the truck as 1) a tow vehicle for our boat, and 2) an experimental/project vehicle. I may or may not make it electric some day, and may or may not pull the engine out of it to use in a lightweight sportscar.
My daily driver is an '89 civic hatchback.
If using canvas, I would attach a sheet of clear plastic (whatever they use for the rear window on jeeps), or if something else is used for the bodywork (aluminum or plastic), I'd use a clear hard plastic like plexiglass for the window.
I agree that the wheel skirts should go to the floor, but they'd have to come up again when the snow falls.
By the way, the truck cost me $300.
Old 06-09-2008, 12:36 PM   #6 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
the rear angle looks too steep in both the pictures.. raise the back up a few inches off the bed and i think you got it.... you can also cheet and add a horizontal lip spoiler to extend out the length a bit longer ..
Old 06-09-2008, 12:40 PM   #7 (permalink)
Veggiedynamics
also curve it a bit as you can get the air to follow a curve a bit .. look at a prius for inspiration.. and also make the center higher than the ends near the corner of the bed.. makes a curve to help air not get turbulent if it falls off the bed cover ..
DIY Frontal Area Measurement newtonsfirstlaw DIY / How-to 5 11-22-2015 12:46 PM
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
Regearing a tranny - Toyota Tercel Daox EcoModding Central 27 05-29-2010 09:32 PM
Metro XFi sells on eBay for $7k. Are efficient used car prices going up? MetroMPG General Efficiency Discussion 16 05-29-2008 06:51 AM
