LPG driving for Economy?
My current Car share Colleague is off to pastures new in April, So I'm landed with having to drive myself to work every day now..
To this end, for the benefit of my wallet, I have acquired a 1997 BMW 328i touring (estate) fitted with a single point LPG coversion. Car has a 5 speed Manual transmission This has the benefit of giving me fuel at circa £0.83/Litre as opposed to £1.35/Litre for petrol. I know I wont have the full 193 ponies available on LPG, but as its my commuting car, that doesnt matter. I'm more interested in making it as cheap and efficient to run as possible:thumbup: My route is 25 miles each way, approx 22 miles motorway (rush our, so plenty low speed/accellerate/slow down) scenarios 3 milees town driving- fairly free flowing At the moment, my iS returns circa 40mpg on this run- I'd like to get as close as possible- I realise I have a larger engine and LPG is inherrently worse for MPG due to lower energy content, but I do have High gearing (in relation to the iS) and more torque:rolleyes: Initial thoughts are similar to the iS 42psi in the tyres P&G where possible (will it work with LG?!) I'm open to all tips and suggestions:thumbup: thanks Neil |
is it dedicated LPG only
is it duel fuel, pump gas and LPG or is it a converted gas auto :confused: dedicated engines commonly have a little higher compression, then one that must also run on gas. LPG just like ethanol, has lower BTUs and has a high octane rating, and very much likes high compression. but when the engine was made orignaly to run on gas, but is converted to LPG, the economy will suffer a bit do to having 9 to 1 or so comp. buy no means is this your cars mpg numbers, but it gives a "ball park" as to what is lost in MPG from gas to LPG i wanted to show a car but i could not find a USA car that is LPG/gas powered off the dealer lot.... there's a few CNG cars, but not LPG cars. Compare Old and New MPG Estimates |
Neil,
My car is converted to run on LPG as well as the factory fitting of unleaded petrol and the general level of economy is around 10 / 15% less with gas than petrol. The gas does vary in quality and mix and here it is possible to buy either LPG (Propane and Butane mix) or just straight Propane with no butane. The propane and butane mix will give better economy but the 100% propane gives better starting and performance with lightly less economy. P&G will work with lpg. I don't do it but a taxi driver I know does. Apart from the lower costs at the forecourt there is no practical difference running on LPG and all the usual tips and tricks apply as they do to a standard petrol powered car. The oil will last longer since there are fewer combustion byproduct deposits but LPG is more demanding on the ignition system than unleaded so good quality plugs and leads are a must. I use NGK plugs and change the leads every 100 000 klms (about 60 000 miles) just as a precaution. Peter. |
Colder plugs are a must, and you should make sure your particular engine doesn't have valve seats that are sensitive to LPG.
I love LPG, but at the moment, my LPG-powered car is idle. Don't have time to work on it, so I commute with the diesel instead, or whatever test unit I've got at the moment. |
