LRR Tires Make a Huge difference
I had Bridgestone Ecopia tires from Costco. I went through discount tire and asked for LLR tires, I got kumo tires that were not LLR. My average has gone down by quite a bit. I used to be able to get 45-48 easily. Now I struggle to get 40mpg.
With any luck they'll improve as they wear in - old tires tend to have lower RR than new ones. But yes, LRR makes a tremendous difference.
Yep. It seems to take about 1k miles before any tire really breaks in and starts performing at its optimal mpg efficiency. When I put on new EP422+, I notice an immediate drop in mpg. After a month of normal driving, I'm back to where I was.
In my experience LRR tires make a 2-4mpg difference vs. non-LRR once they've "broken in." |
Should've taken it back and gotten them to swap out tires for actual LRR ones since they didn't follow instructions.
I had Ecopia tires on my 05 Prius, 09 Prius, and 16 Spark EV. Good mileage but garbage tire. Dry traction was OK but they are horrible in the wet.
I switched from Bridgestone Ecopia (185/65R15) to Bridgestone Turanza Serenity Plus (195/65R15) on the Prius and dropped from and average of 49.5 mpg to 44.2 mpg. The better grip and turn in was worth it though. In the Spark EV I went from the Ecopia to BFGoodrich Advantage Sport A/S (195/55R15) and dropped from 4.6 miles / kWh to 4.2 miles / kWh. I think that BFGoodrich is a good compromise between price, grip and rolling resistance. I have them the Astro and Sportwagen. |
Pity the US still doesn't have tire labels like EU, you might find a tire that is sold on both markets tho.
http://newsletters.kwik-fit.com/imag...-labelling.png |
Lots of problems though:
Your rating looks much better. |
Agreed. The External Noise rating caught my eye.
It becomes more important with electric vehicles. |
