Originally Posted by Macskyver
That's very interesting. The factory air intake on the car is right above the radiator in the center of the car. It's almost like the Lexus engineers knew what they were doing. I do know that they used the same wind tunnel to develop the LS430 as was used to develop the high speed bullet trains. There's definitely a lot of though already put into the aero of the car.
Yes; many performance orientated cars now have the engine intake going over the radiator to something of a forward facing Bell Mouth (Some small Ram Air effect) in the cool/denser air ahead of the radiator.
VW Golfs etc do this and this guy has tested a number of aftermarket intakes.
NB that while the engine still sucks more than the wind blows air into the intake, there is a decrease in the amount work the turbo/engine has to do at sucking in air.
Also NB that any sucking in air from the front somewhat decreases the frontal area and thus aero drag of the car...
Ideally you'd want 2 (Bell Mouthed) intakes with an automated valve:
One as above and ahead of the front grille too.
And another taking in hotter air from behind the radiator and somewhat close to the exhaust.
The hot air intake would be for economy, thx to better vaporization and something of an Atkinson compression stroke effect.
The cold ram air intake for when you want power.
Then some sort of control system based on temperatures, load, throttle position etc.
But that's the ideal and thx to the complex control system required; not something easy to DIY.
Besides
all this ads weight (and complexity) and in urban driving; 68% of fuel is used accelerating mass, vs 14% overcoming aero drag, so light and simple wins out until some serious research is done by a car company.
If I read that figure correctly it seems like I should use the factory air intake location, and that I can place hood vents really anywhere. One thing that gives me pause is that there is weatherstripping around the hood. I think the intention must have been for the air to travel underneath the car. The car has a lot of belly pan pieces from the factory, but they are pretty gnarly from oil leaks etc.
Looking at the figure; you'd definitely want this in and around that area of lowest pressure.
ie: that 1st downward spike in the graph.
IMHO
that area on any car starts where the nose has just finished curving from vertical to however close to horizontal the hood ever gets and does not extend back very far at all...
Weatherstripping:
If you want to block (engine) noise; you go airtight, with as thick and dense a 'wall' as possible. (thick=impractical; heavy)
ie: While the weatherstripping may block some rain ingress, it's main purpose is to seal of any avenues of noise (sound waves) egress in areas close to and upwind of the driver's/ occupant's ears.
The venting of the engine compartment air below the car gets the sound wave avenue as far from and 'downwind' of said ears as possible and the whole car underside acts as something of a muffler.
If you were to build such a radiator vent; ideally you'd want the same weather-stripping sealing the gap from the vent, to around the (aero) slot in the hood when it's closed.
The radiator is not a vibrating etc noise source, fans excepted.
ie: The hood remains as noise and air/water tight as usual, except for the exit slot from the radiator/s.
A hood vent / (aero) slot in the right place, but
without that below hood duct would work to minimize 'below the car exit flow' to a certain extent however.
Simple and light is good.
And rain wont be going in against the airflow at anything above a couple of mph.
NB that as much or more rain is coming in the stock grille, through the radiator anyway and splashing up from below etc, so the under hood electrics should already be waterproofed enough.
(Then if you really want to go to the N'th degree; you vent the after radiator engine bay air to a slot in the roof (that 2nd low pressure downward spike in the graph) via the A-pillars!
That's just an idea of mine. At this time... but I expect it will eventually 'magically' appear in future rally etc cars.
