Old 05-24-2025, 09:29 PM   #61 (permalink)
Originally Posted by Macskyver View Post
For AC, I am planning on getting a vintage air system. I am not sure if they have any features to enhance economy, but I doubt it.
For the alternator, I am leaning towards getting a one wire alternator for simplicity sake. I am not sure how efficient they are, but I know the wiring is simple.
I'm definitely going with LEDs for the lights. For interior lights, it will just be what the aftermarket gauges have and maybe a dome light or LED strip in the headliner. I won't have any door lights or visor mirror lights or anything like that.
That would look sick to have the bellmouth intake in the front bumper like that... but probably not going to happen.
Vintage?
IIRC the old crank driven compressors are not efficient.
I'd look for mod-ability to field voltage control for future mod-proofing.
Ye; getting LEDs into the instrument cluster to replace ALL bulbs is not easy.
IIRC there's a discussion on it here somewhere.
Bell-Mouth:
This guy seems to be 3D-Printing some decent products with projector headlights that have high and low beam. (Legal?)
I like the 'white' ones that light up which should improve visibility. (and kinda messes with your head! )
This guy has them in so you can see what they look like, but not plumbed to the airbox. (Dumb)
Old 05-24-2025, 10:59 PM   #62 (permalink)
Macskyver's Avatar
Originally Posted by Logic View Post
Vintage?
Bell-Mouth:
Vintage air is the brand for the aftermarket HVAC system. Despite the name, the systems are quite modern. It would be something like this: https://www.speedwaymotors.com/Vinta...RoCER8QAvD_BwE
For the headlights, I would try to use the factory lenses but get LED replacement bulbs or do some sort of conversion kit. If it looks like it will be too much of a pain, I'll just use the factory HID bulbs.
Old 05-25-2025, 09:52 AM   #63 (permalink)
Oh...
no:
The projectors are about having enough space left over to implement ram air (from a high static pressure area?), through where the headlight/s used to be.
Not specifically about saving watts with higher Lumens per watt.
But bigger ram inlets is not better.
The Straight Scoop: Exploring the Science Behind Hood Scoop Design
It's more about static pressure recovery after the inlet.
ie: Increase the volume after the relatively small bell mouth at wall angles of no more than 7 degrees to keep flow laminar.
This changes flow into static pressure in the filter box.
After that it's std Bell mouth out of the airbox to the manifold.
Then the manifold has tuned length bell mouthed intake tracts to each cylinder.
So it's kinda like car aero, turned inside out to improve aero inside the plumbing.
Old 06-07-2025, 02:17 PM   #64 (permalink)
Macskyver's Avatar
It's been a while since my last post. My brother came down to visit and he helped me get organized in the garage and make some decisions regarding the build. I decided to pursue the path of simplicity and committed to not to using any of the original interior, trim, carpet etc. I basically trashed it. Here is one load going to the dumpster:
There will be more. I still have the door panels to finish removing and I will eventually get rid of the original wiring. Speaking of which, we weighed the wiring (not including door wiring) and it came out to about 120 lbs. I'm not sure exactly how much weight was removed from the other interior parts, but I'm guessing it's significant. I'm really curious how low the final weight will be.
Old 06-14-2025, 01:40 AM   #65 (permalink)
Interesting project. I'd like to offer a few observations.
- While there's nothing wrong with wanting a bulletproof build, I think you're a little too concerned about a Carrington event. In the Youtube video below, Richard Hammond of Top Gear parked a car inside a Tesla Coil area, and the car was zapped directly for several minutes. Afterwards, he started it up and drove away. That will be far more intense than what the Sun is going to expose us to.
- On the interior being bubbled up, that would be heat damage. Some infrared blocking tint on all the glass including the windshield will help with that while also making the car interior a lot more comfortable. But, since you pitched it all anyway, the link below shows a mid-size pickup dash made of carbon fiber. I'm probably going to use one like it on my own project, and they make several different designs. These are meant for race cars so they are actual carbon fiber and not overlays.
https://www.fiberwerx.com/collection...11631156559919
- On the sunroof, I think you are making a mistake wanting to use wood. Wood and metal have different expansion rates, so I think you're setting yourself up for a leak here. Even in pickup beds where the're using quite thick pieces of wood, the wood is put in using spacers and overlaps to allow it to expand and contract with the temperature. A better solution would be to order a replacement roof panel for a non-sunroof car. If one is not available, a good body shop can graft a piece of steel in its place. You could also retain the sunroof, and have a scratch resistant plexiglas replacement made for the glass. It' the glass that has 90 percent of the weight anyway. If you don't mind not seeing through it when closed, you can also buy a carbon fiber sheet and make a glass replacement panel from it. Alternatively, the carbon fiber sheet could be used to just fill the hole if you don't want a sunroof at all.
- For the clutch pedal, I'd suggest getting all that out of a Camaro. The Camaro is roughly the same width as the Lexus, so the pedals should be spaced correctly. You would then just need to make an adapter to let the pedal assembly bolt in. And, Camaros came with T56 transmissions, so the pedals should work well with it. Cable fuel pedals are also not that hard to work up, it just needs to be screwed to the firewall then a hole drilled for the cable to pass through.
- I'd also rethink replacing the electric windows with manual. I have manual on my truck and they are a pain. I can't see them being more than a pound lighter than electrics anyway.
- Insulation, I wouldn't bother with the bubble wrap. That stuff only has an insulating value of R1, so it's like nothing at all. You'll also want to avoid a lot of the home insulation as that stuff puts out pretty toxic smoke when it burns. I'm kinda thinking Havelock wool or Thinsulate for my own project. If you have the money, there's also Aerogel but that's getting into high dollar stuff.
- Speaking of lightweight, consider using aircraft carpeting in the car. Some of that stuff only weighs 1100 grams per square meter or 33 oz per square yard, and it's fire rated for aircraft so a lot safer than ground based stuff.
Hope some of this helps.
Old 06-14-2025, 01:06 PM   #66 (permalink)
Macskyver's Avatar
I wouldn't say that I am all that concerned with the Carrington event. I'm kinda half joking on that front. That being said, I don't think that Tesla coil experiment from Top Gear accurately represents what would happen during large solar flare. But who knows really..
Those carbon fiber (and fiberglass) dashboards are an interesting option. That might save a bunch of time. Thanks for that link.
I'm not too worried about the sunroof being wood. It's really going to be more like fiberglass as it will be covered with a clear fiberglass layup. It still has different thermal expansion rate than steel, but with how small of an area it is, and how I plan on attaching it, I'm pretty sure I'll be fine.
The Camaro clutch pedal is a good idea. That was one of my main considerations. The problem was that the readily available used peal assemblies (in good condition) weren't cheap enough relative to a brand new aftermarket pedal assembly that's meant to be somewhat universal. I ended up getting a Tilton clutch/brake pedal assembly and a matching throttle pedal assembly.
I have gone back and forth on manual vs. electric windows. I'm not one to roll windows up and down very often so either option would be fine. I just sorta miss the mechanical simplicity of having manual windows. Maybe it's misplaced nostalgia.
Those are good ideas for the insulation and carpet. I'll keep those in mind.
Old 06-14-2025, 01:39 PM   #67 (permalink)
Carrington Event is a local maxima. The magnetosphere hadn't collapsed back then. The poles are wandering.
The Charlemagne Event:
Wikipedia
774-775 carbon-14 spike - Wikipedia
The 774-775 carbon-14 spike is an observed increase of around 1.2% in the concentration of the radioactive carbon-14 isotope in tree rings dated to 774 or 775 CE, which is about 20 times higher than the normal year-to-year variation of radiocarbon in the atmosphere.It was discovered during a study of Japanese cedar tree-rings, with the year of occurrence determined through dendrochronology. [1]
SYFY Official Site
Bad Astronomy | A solar flare in 774 AD changed Earth's ... - SYFY
The obvious candidate for such a thing is a very powerful solar flare, an explosion on the Sun created when intense magnetic field lines tangle up and short circuit, releasing huge blasts of energy and particles. But the 774 event was so powerful that at first scientists were skeptical it could be from a...
Now for the ball scores: 4 to 3, 6 to 2 and 8 to 1 -- Firesign Theater
