Lugging
I have a question regarding lugging while P&Ging.
Most of my commute is on roads with speed limits in the 30-40 mph range. When there is no traffic behind me, I will generally glide down to close to 30 mph, which is about my minimum 5th gear speed (V-6 ranger, 5 speed stick). If I extend my glide a little to long or have some sort of uphill, I sometimes get into the lug zone a bit. I can stay in 5th, with very light throttle and accelerate very slowly, smoothly, or I can momentarily drop to 4th or sometimes 3rd, accelerate hard and be back into 5th fairly quickly. Which is better? Do I burn more fuel putting up with a few seconds of very light throttle to nurse it out of the lug zone or should I go to a lower gear where I can go to a more efficient 80% throttle. I do not have a scan guage, unfortunately. Does anyone have a BSFC graph for the vulcan 3.slow V-6? |
I'd suggest downsifting anytime you're lugging. You don't have to keep the rpms THAT low.
Also: get a scangauge! It'll pay for itself. (And you can always re-sell it later.)
Note there are less expensive options than the full SG 2, such as the ScanGauge E and the UltraGauge. |
i am guessing that downshifting probably does make sense in this case, as fuel efficiency just above lugging, probably ain't anything to write home about. i 'spose a little extra left leg exercise is good for me, anyway and doesn't really cause much extra wear. |
What rpm are we talking about? I like to run mine fairly low, pulsing from 1300 rpm on up. What's efficient is 80% LOAD, not throttle. At very low rpm, that load level comes with the throttle just above idle.
Not really sure what the revs are, as I have no tach. Interesting point about the difference between load and throttle position. I wasn't aware of it.
I 'spose I will modify my p&G technique a bit and incorporate 3rd/4th gear a bit. |
Pete -
CarloSW2 |
I think the art of driving efficiently has more to do with how you decelerate and what you do with your velocity once you have it than how you accelerate. Use a gear that allows moderate acceleration and a throttle position that is just backed off of where adding more does not increase acceleration rate. That is about as good as you can do without instrumentation.
