lugging kills my mileage
For my Subaru, I noticed that I get better fuel economy in a pulse if I make the same amount of power at higher rpm vs. lower RPM at wide open throttle plate.
In short -> 3/4 engine load at 2000rpm is better for me than full load (0 vacuum) at 1500rpm. I have kept an eye on air to fuel ratio and they are always stoich so long as i don't exceed 3500rpm. the only difference I see on my instruments is higher ignition timing at higher RPMs / lower loads. Monitoring the "horsepower" gauge and trying to maintain a steady power output has yielded better results than keeping a high engine load during the whole acceleration phase. Just wanted to share my results and get some feedback. thanks! |
have you tried get up to the speed you want then switch to the highest gear possible.
once i get up to 60kph in 3rd i switch to 4th. |
There are a couple of things going on there.
First most engines have their best BFSC at about 2000 rpms give or take. Second at full throttle most engines run a little rich to prevent detonation. |
get up to speed how? if you mean WOT then no, that gives me horrible mileage. anything above 3000rpm and my car really burns a lot of gas. high load and over 2500rpm it also burns a lot of gas. I found being gentle is the best. accelerating at 30kw power range.
so in my notes higher loads are better at higher vehicle speeds while lower loads lead to better results in city driving. |
This should help you find your best acceleration load.
ya unfortunately that requires a 4.06 firmware and two scangauges. I got neither :(
I have a full throttle engine dyno for my engine which determined 2400rpm to be most efficient. but im not sure how accurate it is since I heared its just an estimate. |
0 vacuum is for all intents and purposes full throttle, maximum dynamic pressure etc.
2400 rpm may very well be where your engine is most efficient at full throttle, where it is more efficient at lower throttles will take time and experimentation. That's why there is a BFSC chart for many engines http://ecomodder.com/forum/showthrea...-got-1466.html |
but certain things like AWD torque distribution and valve lift is based on throttle input. Yes I know about BSFC charts but there is none for my engine as they are company secrets now. experimentation always has not delivered solid results. whether I shift at 1.5k or 3k 80% load I still get identical crappy mileage. but if I forget about engine speed and keep a constant power output of say ~40hp I get better mileage. its hard to maintain 40hp anywhere on the powerband except at ~2k rpm. below that it leads to full load and enrichment and above that power output shoots up and throttle becomes more sensitive.
Efficiency log for: Mean Green Toaster Machine - 2006 Scion xB Lifetime Fuel Economy: 49.4 mpg (US), 4.8 L/100 km, 59.3 mpg (Imp) 90-day Fuel Economy: 46.9 mpg (US), 5 L/100 km, 56.3 mpg (Imp) 3-tank Fuel Economy: 47.6 mpg (US), 4.9 L/100 km, 57.1 mpg (Imp) EPA Combined Rating / % over rating: 28 mpg (US) / 67.3% (based on 90-day fuel economy) Total fills: 121 Average cost per gal/L: $3.27 per gal (US); $0.00 per L (price data entered for 121 fill/s) Average cost per fill: $24.61 Average distance cost: $0.07 per mi. / $0.04 per km Total fuel used: 909.8 gal (US), 3444 L Total distance traveled: 44898.7 mi. / 72257.5 km Total cost: $2,977.61 Total fuel saved vs. EPA: 693.7 gal. (US) / 2625.9 L Total saved: $2268.4 (based on avg. cost per gal./L) Average tank distance: 371.1 mi. / 597.2 km |
