Old 12-02-2014, 04:13 PM   #1 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Should I modify my front bumper again?
This is my bumper now:
Would I be better off filling in the area between the bumper and splitter like this?
ID:	16533   Click image for larger version
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
The Following 2 Users Say Thank You to Gasoline Fumes For This Useful Post:
aerohead (12-02-2014), tyronasauras (12-02-2014)
Old 12-02-2014, 04:56 PM   #2 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Where is the air intake for the radiator ?
Do you have a belly pan ?
The mod seems easy enough to do, even using a piece of cardboard.
So yah - go for it.
I would speculate that it might channel air over the hood a tiny bit more, but that overall, the difference will be negligible.
If angled up or rounded though, you might see more flow over the hood and it might lower the stagnation point.
BTW : I copied your wheel spats :
The Following User Says Thank You to Cd For This Useful Post:
Gasoline Fumes (12-02-2014)
Old 12-02-2014, 05:36 PM   #3 (permalink)
should I
Fiat research showed that a vertical face,or one which lays back slightly,has a drag advantage over one which is undercut.Your splitter is taking care of the undercut,but filling in the void makes for more sectional density.
If you watch the video of the T-100 at Darko,you can see how it will flow.
Cd (12-02-2014), Gasoline Fumes (12-02-2014)
Old 12-02-2014, 05:51 PM   #4 (permalink)
I'd say yes because those look like chains holding the diverter up, which won't prevent it lifting. So not so much for sleekness, but to stiffen the whole structure.
At Bonneville they used adjustable rods.
aerohead (12-02-2014), Cd (12-02-2014), Gasoline Fumes (12-02-2014)
Old 12-02-2014, 10:35 PM   #5 (permalink)
Too many cars
Gen-1 Insights
Gen-1 Insights
So yah - go for it.
Radiator inlet is currently where the plate is in the pic. I'd just have to move the shutters out or run a duct to them. Or copy your scoop!
http://ecomodder.com/forum/showthrea...ore-29966.html
You can see the sagging in this pic which I corrected with the chains.
I have a partial belly pan, but I haven't installed it yet.
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
1988 Honda CRXFi
1994 Geo Metro
The Following User Says Thank You to Gasoline Fumes For This Useful Post:
aerohead (12-03-2014)
Old 12-03-2014, 01:32 PM   #6 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 42.77 mpg (US)
Are you kidding? This is ecomodder.com, and you have to ask if you should modify some more?
The Following 2 Users Say Thank You to JRMichler For This Useful Post:
Cd (12-04-2014), Gasoline Fumes (12-03-2014)
