Made in USA , 43mpg 4DSD $20.ooo
not what you are expecting ...Behind the Wheel: 2012 Volkswagen Passat | Gear Patrol
$20K. Hmmm. Cheapest in the UK is £19K, which is ~$30K.
Cheating ......s! :D |
I love the idea of getting the carp out of cars, since you can buy it separately if you wish, usually much cheaper than options, upgraded easily and not a potential electrical problem just when it becomes obsolete. Power outlets sure, pass on the components.
At close to end of life, my stripper no option F150 is probably worth close to the same as a Mercedes that cost several times as much when new. Cudos to VW. Of course the additional cost of fuel and extra btu content must be factored into any calculation. regards Mech |
The Passat TDI that gets 31/43mpg (35mpg combined) cost $25,995 before shipping. Sonata hybrid built in the US, 35/40mpg, 37 combined, $25,795 |
VW is going in the same deathtrap that GM and Chrysler went trought in the last decade. ''its ok to sell a lot of crap car if you manage to make profit out of it''
VW, Toyota, and Honda all are complacent, and are losing ground because of it.
And all the new cars look ugly, better to stick with the classics!
Yeah VW really screwed up in the US. The reliability is abysmal and the products they're offering are way behind any of their competitors. They're still trying to sell the 2.0 8 valve motor from the early 80s, drum brakes, hard plastic interiors etc. Really pathetic stuff. They need to shape up or leave the US market. I'm tired of seeing their Mexican made garbage on the backs of tow trucks.
Are you looking at VW or VAG ?
Well, at least some company is trying to bring diesels to the USA. Maybe if they made the engines in Germany the reliability would be better.
http://en.wikipedia.org/wiki/Volkswa...America#Yearly |
whatever - 500 lbs and thousands of dollars less
whatever the new Passat weighs 500lbs less than last years and the price is thousands less than last years and it gets better fuel economy and has a better cd - i can still climb into the trunk and close the lid and i am over 6'2" and weigh 225 lbs . not many new cars weigh 500lbs less and cost thousands less than last years versions and they are as fast as a runaway camel with his hump on fire and handle like slot cars . made in USA too . the TDi s get 43 mpg with up to 2.4 bar of boost , stock , that would be 1.4 bar over baro or about 18psi of boost , stock. it will take a while for the koreans and chinese to clone / copy / steal / implement that technology , successfully . i like it - pbbbt - so there . |
Obviously you're not bothered by facts. You didn't know the price, you don't know the weight, you don't realize that most of the components come from Mexico or Europe... stop making a fool of yourself. Its bad enough to have to read attention ***** blue text. 2012 2.5 Curb Weight 3165 lbs 2012 TDI Curb Weight 3359 lbs 2012 3.6 Curb Weight 3446 lbs 2010 2.0T curb weight 3331 lbs |
2012 Volkswagen Passat 2012
follow the facts , but look under 2012 which would be the year i am referring to then look under 2012 Volkswagen Passat which is made in USA carry on |
I don't recall any claims by VW that their EU Passat had become 500lbs lighter - and it'd have been serious auto news if it were !
Trims & Specs < Passat < Models < Volkswagen of America Just for a quick recap: The TDI costs $26k not the $20k you claimed The new Passat does not weigh 500lb less than the previous model. Most of the components including the engine and transmission are Manufactured in Mexico or Europe. Final assembly point is in Tennessee. Any other fun facts you want to share with us? |
assembled and manufactured in the USA by workers in USA base price is 20k yes there is 500 lbs less weight i have actual VW information that you do not have and did i add VW sales for the year so far are up 22% over this time last year just returned a 2003 passat with AWM 1.8 turbo to the customer with the original engine and transmission and 273k miles ... how many 2003 korean imports are on the road with 273k miles ? .... 2 ? 3 ? less ? |
Weights :
2012 US Spec Passat 1436 - 1563 kg - from the VW website link in the article 2011 Passat 1451–1618 kg - Honest John UK spec Passat 2010 Passat 1348–1800 kg - Honest John UK spec Passat I would take the bottom figure as the top one includes models such as the R32 which does not carry over to the new range. There seems little difference to me, certainly no 500 kg saving. Are you sure its not lbs ? Any car will run forever given regular maintenance and care. |
Curb Weight: 3165.80 lb (2.5) 3359.8 lb (TDI) 3446 lb (3.6) Trims & Specs < Passat < Models < Volkswagen of America Quote:
So you actually work for VW and you still can't get your facts straight? Just keep digging the grave to your own credibility. It died a long time ago and its starting to stink. |
