Old 10-18-2010, 02:08 PM   #1 (permalink)
klr 650 - '08 kawasaki klr 650
The van - '15 Dodge Grand caravan Avp
side view mirror aero mod
first i have a maxima with a Cd of .31 maybe .30 now that i have a grill block, but anyway i have been noticing the mid to late 90's camaro's side mirrors are like an extension of the body panel. i.e very aerodynamic. the body molds up into the mirror. i am trying to not spend any money on aero mods and deletion is out for the drivers side so i thought use that tear drop aero shape attached to the body and covering the mirror or just go from the mirror to the body with cardboard. pictures are included of the camaro and some drawings of my car.
ID:	7138   Click image for larger version
ID:	7139   Click image for larger version
ID:	7140   Click image for larger version
ID:	7141   Click image for larger version
SCANGUAGE IT REALLY WORKS
Old 10-18-2010, 02:35 PM   #2 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
i don't want to temper you enthousiasm, but i'm not sure if such a mod will have much benefit, i'm not saying it can't, but without propper testing it's as likely to have and adverse effect than to cut drag.
wikipedia lists the camaro you're refering to as having a Cd of 0.338, if the figure is correct that's not all that good for such a sleak looking car.
on the other hand i do know one car wich has similar mirrors and an 0.28 Cd the opel vectra B http://upload.wikimedia.org/wikipedi...D_sedan_04.jpg
so the setup isn't bad per definition, however the curent trend seems to be to move the mirrors away from the body.
if you want to try this go ahead and perhaps fuft test the results.
aerˇoˇdyˇnamˇics: the science of passing gass
*i can coast for miles and miles and miles*
Old 10-18-2010, 02:54 PM   #3 (permalink)
The PRC.
I think others have tried modding mirrors but for the ultimate and cheapest mod you may be able to go with interior ones and delete the external mirror except for when you are going in for safety tests, if they are required where you are.
Or if you like 'customising' maybe you could try some 'Emm-Freees' - aka BMW M3 styleee mirrors ?
Old 10-18-2010, 03:00 PM   #4 (permalink)
It is the trailing shape that matters more to reducing drag. I would try doing some tuft testing to see what is happening around the 'A' pillars and the mirrors -- it is more complicated than you might expect.
I wonder if a triangular plate trailing from the underside of the mirror would help? By removing the air flow on one side, it might calm things down, and reduce the turbulence?
PaleMelanesian (10-19-2010)
Old 10-18-2010, 03:30 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
talldudenumber5 -
Yeah, I remember those. The first Ford Probe (in the Ford aero-design-era) had something similar :
Neil is right. Some racing mirrors have clear attachments that surround the mirror. The goal is to "boattail" the mirror while keeping functionality.
CarloSW2
American Solar Energy Society
Old 10-18-2010, 04:08 PM   #6 (permalink)
Chang Ho Kim did this to his winning Honda CR-X HF:
http://ecomodder.com/forum/showthrea...tml#post169206
Old 10-18-2010, 07:12 PM   #7 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
I would try taking it off and putting tape over the holes. Then go do some ABA testing or coast down tests. If you see a gain great, if not then put the 3 bolts back on and put that mod in the does not help this car bin.
Old 10-18-2010, 07:13 PM   #8 (permalink)
Gen II Prianista
Rokeby's Avatar
I know what follows isn't DIY. Nonetheless it may be interesting,
maybe merely entertaining, maybe downright ridiculous:
These folks say that at 150 MPH, it takes 0.93 less HP, 1.43 HP at 200 MPH ,
to move their patented Professional mirror with their AERO extension through
the air. (Click to enlarge.)
Name:	racing mirror.jpg
From www.racemirrors.com Cost: ~$165 USD
Carbon fiber mounting stalks: "Care should be taken not to use these mirrors
as 'helmet hangers' or push locations."
The sickest 'racing mirrors' on the net my be this for the Honda S2000 with an
alleged an aerodynamic advantage:
From Spoon Cost: ~$900 USD
Estimated payback in 200,000 CE.
Old 10-18-2010, 08:05 PM   #9 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Rokeby -
Looks great, but I think you have to be born with a silver spoon in your mouth to afford that one!
(beat you to it, Old Tele man!)
CarloSW2
Old 10-18-2010, 08:21 PM   #10 (permalink)
Gen II Prianista
Rokeby's Avatar
I suppose there may be some merit to the AERO extension idea.
I can even see that at least an operating prototype would be easy to make
from some clear plastic with a slight inward taper.
But, come on!
0.93 HP at 150 MPH, power being a cube-function of speed and all.
I suspect that there isn't much to be gained at and below the posted speed
limit... p&g speeds.
Side View Mirror Replacement for under 8 dollars! Sean T. Aerodynamics 41 08-19-2012 08:05 PM
Side View Mirror Downsize cfg83 Aerodynamics 20 07-13-2011 12:22 AM
Inside side view Mirrors (Mirror Delete) bbjsw10 Aerodynamics 9 03-25-2011 08:46 PM
DIY: Side View Mirror Delete, Side View Camera Addition SVOboy DIY / How-to 26 06-07-2010 06:09 PM
Bicycle side view mirrors? cfg83 Aerodynamics 2 02-15-2008 11:54 AM
