EcoModder.com
-   Motorcycles / Scooters (https://ecomodder.com/forum/motorcycles-scooters.html)
-   -   magnetic engines (https://ecomodder.com/forum/showthread.php/magnetic-engines-4859.html)
oldtech1 08-31-2008 07:48 AM
magnetic engines
i have attempted to make a magnetic engine like those you might have seen
on youtube.ive tried 2 different types
YouTube - Perendev magnetic motor
YouTube - magnet motor FREE POWER PERENDEV NO GASOLINE
ive had poor results from both thou i see the potential for the application
if they really worked .
for solar charging i have found a alternative to pannels that might get more amps if a alternator and sun trakker is installed.
YouTube - Solar powered thermo-acoustic Stirling Engine
jeremy128 08-31-2008 09:55 AM
Insert debate about the first law of thermodynamics here.
oldtech1 08-31-2008 11:35 AM
stirling motors already in california power some of there grid
YouTube - Sterling Dish 500MW solar power plant
jdub 08-31-2008 12:23 PM
Those are not magnetic engines though
Those are engines that run off a temperature gradient from ambient air and focused solar heat.
The original post is about something totally different than Sterling Engines.
oldtech1 09-01-2008 12:20 PM
you are correct my post is in 2 pieces.
the first 1/2 is about the poor performance of magnetic engines.
the second is on using stirling engines as a alternative to solar pannels to
charge ev's
jdub 09-01-2008 03:12 PM
Sterling engines
charge ev's
I think Sterling engines are pretty sweet in concept and its amazing how old the idea/technology is, however plans for highly efficient and economical version are closely guarded trade secrets and as a result its impossible to find readily available plans for DIYers. you are seeing them in use in more and more products though.
Copyright ©2000 - 2020, vBulletin Solutions Inc.
