EcoModder.com
-   -   magwheels and tires (https://ecomodder.com/forum/showthread.php/magwheels-tires-5084.html)
gasti_ako 09-13-2008 11:04 AM
magwheels and tires
i just want a confirmation if my understanding is correct about mags and tires.
it doesn't matter if you are using 13s or 18s because:
smaller diameter overall=one revolution of your tire covers less ground but effectively spins faster per minute
bigger diameter overall=one revolution of your tire covers more ground but effectively spins slower per minute
what will affect economy will be the width of the tires. the wider you go, the higher the friction your engine's power will have to overcome. more contact patch=more friction=more energy needed to overcome that friction.
is this true?
Ryland 09-13-2008 11:29 AM
the main reason people tend to go for smaller rims is that they tend to be narrower then larger around rims, and they tend to be lighter weight as well, you are correct that a larger around tire will need to be spun slower for a given speed, allowing your engine to turn slower as well.
the only reason to go with wider tires is if vehicle weight goes up, as wider tires normally have a higher load range, and just like on a bicycle, you want the narrowest tires you can get away with, and a narrow tire is going to need to be at a higher pressure to give the same amount of support.
93Cobra#2771 09-13-2008 02:08 PM
Also remember that as a rim increases in diameter, it gets heavier. If an 18" rim and tire is same overall height as a 14" rim and tire, the 18" will weigh more.
JMags 09-13-2008 02:36 PM
Remember also that a larger diameter wheel will move the concentration of mass closer to the outside of the wheel. I have seen lightweight wheels in up to 20 inch sizes (cost is very high) but the tire weight is most of the assembly then. Increasing the power required to get the wheel and tire assembly moving/stopped.
guitarterry 09-13-2008 03:31 PM
Contact patch is dependant on air pressure. Wider tires are less aero. Heavy tires lower MPG. The ultimate tire is the skinniest, lightest tire aired up to max. The trade off is ride and safety.
brucepick 09-13-2008 03:38 PM
About overall final tire diameter -
Remember that if you change the overall diameter you will need to change your speedometer/odometer for them to be accurate. Or ignore them and use a GPS.
That really doesn't seem practical to me for daily use over the long run.
But there's usually a variety of tire sizes you could use for any given car. They will have different widths and/or wheel rim sizes and profiles (aspect ratio). But there will be several different sizes with the same diameter/circumference that you can use on the car.
Out of those available options, I think the narrowest tire would give the best fuel economy, all other things being equal.
Last summer I went from 197/75-14's to 205/65-15's (all wheels were/are steelies). Same outer diameter. If you look at my fuel log, this summer I haven't been able to match the FE numbers I got last summer. My commute route is different but the overall distance is similar. I suspect my bigger, heavier tires and wheels.
c0da 09-14-2008 08:58 AM
Upgrading rims for mpg purposes really won't help much. If you stick with stock size and go with lighter rims and skinnier tires you may see an increase.
I've personally upgraded my rims from 16" 18lb stock rims to 17" 14lb performance rims, but I had to go with a slightly wider tire. It has had a negative impact on my mpg.
whokilledthejams 09-14-2008 09:50 AM
Are you correcting for the difference in size between your new tires and the stock ones? If they're taller (and there's a good chance they are), you are traveling slightly more miles than your odometer says you are.
For example, I actually run a slightly wider (and taller) than stock tire, with steel wheels. This means I have to multiply my miles by 1.02 (since the circumference is 2% greater than stock), which means my actual mpg is a bit higher than strictly dividing miles by gallons.
In addition, a lot depends on the mix of driving you do. Stop-and-go driving benefits most from lightened wheels and tires, whereas interstate driving isn't hindered by- and might actually benefit from- steel wheels.
Bicycle Bob 09-14-2008 09:54 AM
In the classical literature, tall, skinny wheels have the lowest rolling resistance. Wide tires are bad for air drag, but the radial-belted construction may have changed the traditional advice. Unfortunately, the data is proprietary information, so about all we can do is look up the LRR tires, such as the Bridgestone Potenza RE92 and choose light wheels to suit them. Larger overall diameter will change the speed and mileage readings, but also reduce engine RPM, which usually helps.
c0da 09-14-2008 10:27 AM
whokilledthejams,
Even with the compensation I still have about a 3mpg drop every tank. The tires I have are not only wider, but they are stickier performance tires. I'm looking for LRR for the next ones I get.
whokilledthejams 09-14-2008 10:32 AM
Originally Posted by c0da (Post 61131)
whokilledthejams,
Gotcha. I figured I'd cover all my bases, is all.
Sticky tires will do that. I'd bet your dry traction is great, though! Even if you don't go with LRR's, a decent set of all-seasons will a good bit more efficient, as I'm sure you realize.
c0da 09-15-2008 09:25 AM
I've never had performance oriented tires on any car before and they are definitely fun to have. I guess I can't really complain too much. I push the grip of the tires when I take hard turns without slowing down to save momentum. It's love and hate kinda thing. :D
modmonster 09-18-2008 05:18 PM
i've just swapped my wheels. the last owner had "up"graded the stock 145 tires to 175 alloys. they weighed a tonne!
i think it will really make a difference to my mpg for several reasons:
they are thinner and more aero.
they are lighter and wheel weight is 2x important than bulk weight.
they dont stick out of the wheel hubs like the 175's so i will be able to make taped wheel skirts.
their design will allow me to install pizza pan hub-caps.
& i can sell the alloys and make a tidy profit !!!
some_other_dave 09-18-2008 05:34 PM
Originally Posted by gasti_ako (Post 60979)
it doesn't matter if you are using 13s or 18s...
It generally will matter if you are using 13s or 18s. Unless you've got some really tall tires on the 13s, the overall diameter of the tires on the 18s will be larger. That will make your overall effective gearing taller, which will cut your RPMs/mile down, which will be good for your fuel economy when cruising at steady state.
Offsetting that (probably by more than you gain from the taller gearing) is the general tendency for the larger wheel/tire combo to be heavier than the smaller one. Which means that you lose fuel economy when you accelerate, plus (I think!) a little bit more when you go over bumps. Since pulse and glide is all about accelerating efficiently... You can see where that goes!
So there are effects both ways, but for almost everyone the larger heavier wheels are a loss.
-soD
modmonster 09-19-2008 05:35 AM
has any one done roll down tests with different tires?
that would give some data. would have to do the tests from the top of a hill from 0mph-0mph. otherwise the momentum in the tyres would affect results. i should have done this with my old tyres before the change -thinking about it.
or scan gauge highway testing?
Geebee 09-19-2008 05:51 AM
Also if you goto low profile tyres on bigger rims they will increase noise and rolling resistance.
I was all set to go that route for handling reasons pre hypermiling when I did some research and also found out that they can on a car with fairly stiff suspension deteriorate handling.
I test drove a set and found that the lack of handling in corners if the road is not perfect was real. I am running factory alloys and high quality tyres still.
Google low profiles if you have some time to kill.
modmonster 09-21-2008 04:46 PM
so i just filled up a tank and noticed no difference compared to my previous best. disappointing because i thought the 145 tyres would give a real increase. i will keep the sticky tape on my wheel arches for now though.
