EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   Making my own A pillar pods, how should I adhere these? (https://ecomodder.com/forum/showthread.php/making-my-own-pillar-pods-how-should-i-1732.html)
Chris D. 04-06-2008 01:12 AM
Im making my own A pillar pod using the stock trim and wanted to see if anyone had any recommendations for adhering these to the trim to its bullitproof :D
I'll post up some more pictures for a FAQ on how I made this..
http://i4.photobucket.com/albums/y10...r/P1040524.jpg
reason I'm making my own is because a company called lotek I purchased one from and the guages aimed outside toward the window..
not for me, so I make my own :)
mine is going to hug the A pillar closely.. :thumbup:
http://i4.photobucket.com/albums/y10...r/P1040527.jpg
http://i4.photobucket.com/albums/y10...r/P1040543.jpg
So if you guys could give me some ideas of how to make this work the best, that would be greatly appreciated..
I believe the black plastic is ABS.. :cool:
Ryland 04-06-2008 01:19 AM
I use Polyurethane for nearly everything, because it works with nearly everything, you can get it in black as well, I tend to get the black polly roof caulk, because it holds up to heat well.
LostCause 04-06-2008 05:01 AM
If you want them removable, I'd figure out a way to bolt them from inside the trim piece.
If not, then I would use some of the left over epoxy from your tonneau project. Attach the pod with a fillet of epoxy and fiberglass tape, sand, paint, done...
P.S. I love watching all your projects. Your ability to get stuff done amazes me...:D
- LostCause
Daox 04-06-2008 09:45 AM
Heres a write up by a guy on another forum I visit. Looks pretty good IMO.
http://board.tercelonline.com/viewthread.php?tid=25732
Chris D. 04-06-2008 07:49 PM
Thats sounds like it has some potential.. :thumbup:
- LostCause
nah, fixed position is what i'm aiming for, a clean one piece look is what I like.. :D
- LostCause
Thanks man, I couldnt have done it without the internet and search :D
That turned out pretty darn good..
I like his results.. :thumbup:
I'd like to figure out how to replicate texture too..
Daox 04-06-2008 08:02 PM
This is actually my gauge pod project. Its a bit more involved so I didn't bother posting it. What I'm doing to keep the textured surface is using a wrinkle paint. Its not exactly the same texture as the rest, but its the closest I could find.
Chris D. 04-06-2008 08:39 PM
VERY NICE!! jet fighter cockpit style!
I was thinking for the texture you could use a build up primer and press a grainy section of leather against it while its tack.. Just an idea..
dremd 04-06-2008 10:36 PM
IMHO Attach it however you need, then cover it with either fabric, vinyl, or leather.
A few pieces on the golf are sprayed with Spray on bed liner. works out OK, but not great.
trebuchet03 04-06-2008 10:55 PM
IIRC, you can buy texture paint...I believe it goes on like a primer ;)
If you're going to paint (and not wrap with cloth).... Do try and avoid gloss paints... look for more of a satin or matte finish (buy some samples and try to match).... Nothing kills the aesthetics more than having one gloss panel when the rest have a satin finish :p
dremd 04-06-2008 11:13 PM
texture paint does go on similar to a thick primer, very dry. Bear in mind that it doesn't hide imperfections nearly as much as you would think.
Check out the Fabrication forum at MP3car.com for lots of ideas, but be warned they are the ones that convinced me a 15" tft would fit in a mkiii supra.
http://www.mp3car.com/vbulletin/fabrication/
Chris D. 04-12-2008 10:14 PM
ok, I've got this project back in mind...
I'm about to dive back into this and get things finished up,
still looking for adhesion tips for these into the stock trim..
cfg83 04-13-2008 03:47 AM
Chris -
I have this "pod on a stalk" for one of my todo-list gauges :
UNIVERSAL SINGLE GAUGE SWIVEL MOUNT METER POD gauges
http://cgi.ebay.com/ebaymotors/UNIVE...QQcmdZViewItem
http://images.channeladvisor.com/Sel...lpod_thumb.jpg
Cheesy but get's the job done.
CarloSW2
Chris D. 04-13-2008 04:31 AM
I'm not a fan of guage pods, I've ran them in the past..
pictures are say, 12 years old?
http://www.hometown.aol.com/chargert...rierguagej.jpg
http://www.hometown.aol.com/chargert...nderneathj.jpg
http://www.hometown.aol.com/chargert...ieldwiresj.jpg
Not classy enough for me.. I like that streamlined look..
so I made this for my car using a pod made for a mustang..
it had some cracks and stuff using bondo.. it held up just fine,
but I want to overkill on the adhesion stregnth..
http://www.hometown.aol.com/chargert...pillershot.jpg
http://www.hometown.aol.com/chargert...ages/image.jpg
dirty finger prints ;)
http://www.hometown.aol.com/chargert...oseupboost.jpg
Daox 04-14-2008 10:15 AM
Good idea. I'll have to give that a shot. The original texture is much more leatherish than what a wrinkle paint would provide. :thumbup:
Chris D. 04-23-2008 02:41 AM
WHoa! an update finally!!!!!
I just found the baddest stuff to use ever in all my experiences of bonding plastic to plastic..
I desided to stray away from the usuall epoxy plastic stuff and I went with the loctite 1 minute no mix..
A bit pricy for how much you get, but this stuffs beyond hardcore..
as I was letting it setup, I bonded 2 pieces of scrap plastic the grey trim I cut off the A pillar and some scrap left from the A pillar pod I trimmed off..
I didnt scuff these like I did to the project just to see how good it works..
I used to sets of pliers for a tug of war, NOTHING.. I was bending the heck out of the plastic and being pretty violent and all that happened was the plastic itself fatigued, the bonding agent laughed at me and just made me feel weak ;)
Heres what I did.. Not a lot, but its a start.. :)
http://i4.photobucket.com/albums/y10...r/P1040648.jpg
http://i4.photobucket.com/albums/y10...r/P1040649.jpg
http://i4.photobucket.com/albums/y10...r/P1040650.jpg
http://i4.photobucket.com/albums/y10...r/P1040651.jpg
http://i4.photobucket.com/albums/y10...r/P1040652.jpg
http://i4.photobucket.com/albums/y10...r/P1040653.jpg
smells a bit like burnt hair, so you KNOW its gadda be good!!!!! ;)
Chris D. 04-23-2008 05:30 AM
I heated up the plastic a little more since the adhesive was holding it in place..
turns out heat plus adhesive wasnt too good of a call LOL
came apart a little bit..
so I just filled it in with this other stuff I bought called Professional Welder..
The Loctite stuff was sweet to work with before I went at it with a heat gun..
I simply used the wire wheel deal on a dremel and the adhesive wears away before the plastic..
So I'll just use this Professional Welder stuff to "grout" it flush and just grind it down and a few payers of primer and It'll be good to go, I still have to add the other pod on the upper side..
The Profess Welder stuff takes 24 hours to setup, so I have some pressure on it..
If I had it my way, I would have bought lots of that Loctite and made quick work of it..
http://i4.photobucket.com/albums/y10...r/P1040654.jpg
http://i4.photobucket.com/albums/y10...r/P1040655.jpg
http://i4.photobucket.com/albums/y10...r/P1040656.jpg
http://i4.photobucket.com/albums/y10...r/P1040657.jpg
http://i4.photobucket.com/albums/y10...r/P1040658.jpg
http://i4.photobucket.com/albums/y10...r/P1040659.jpg
http://i4.photobucket.com/albums/y10...r/P1040661.jpg
this too is stuff I've never used.. hit or miss, no biggie.. gadda experiment
with new materials all the time or ya never find the bigger or better..
