Old 03-30-2010, 10:41 PM   #1 (permalink)
Buggie - '01 Vw Beetle TDI Gls
runflat tires- good / bad?
I just had a set installed, I thought the stiffer sidewalls would help with economy but I'm not seeing anything positive, I'll see how this tank works out
Old 03-31-2010, 12:17 AM   #2 (permalink)
The Geo - '93 Geo Metro
90 day: 45.16 mpg (US)
They are heavier.
Old 03-31-2010, 05:48 AM   #3 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
The pressure will still have to be high to firm up the tread. You also should have a TPMS installed as you might not notice if a tire is low or flat. It happened a friend of mine and his tire wore down to the ply underneath. He never noticed until i pointed it out to him.
ollie
Old 03-31-2010, 10:55 AM   #4 (permalink)
I doubt you'll see any improvement -- like MadisonMPG said, they're a lot heavier than non-RFTs. (They also have a less comfortable ride, and generally are not as good in the handling department as non-RFTs.) I have them as well, and hate them -- going to change them for something else as soon as practical.
Ditto on the TPMS if you don't already have one -- because you won't be able to tell just by looking at them if they're flat!
Old 03-31-2010, 03:03 PM   #5 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Any material that is less bouncy than air, and is not needed to contain pressure or stabilize the tread is going to hurt efficiency. To find the fast bike tires, you just go to the high-pressure rack and squeeze the treads toward the bead, and buy the one that feels limp.
Are hybrid SUVs a good or bad thing? SVOboy Hybrids 71 05-05-2017 03:24 PM
LRR (low rolling resistance) tires - Green Seal report & list MetroMPG EcoModding Central 46 06-05-2015 04:24 PM
Scanguage IGN guage, what is good? 40 either is really bad or really good rmay635703 Instrumentation 20 02-06-2010 10:39 AM
Crapped. 2 tires have bubbles. XyKo EcoModding Central 37 09-04-2008 04:55 PM
The Bad with the Good Lazarus The Lounge 1 01-31-2008 12:30 AM
