Materials - Where to Get Coroplast un the UK
Hi there,
I am thinking of getting some Coroplast (called Correx in the UK) for an undertray. Instead of buying the pricey 4mm stuff from a signmaker I think I'm going to use 2 layers of 2mm black material like builders put down instead of ply these days. It's around £4 - £5 a sheet (2.4m by 1.2m) from a local builder's merchant. Trademate by Travis Perkins (No association - other builder's merchants are available who may stock correx sheets) I had to sign up for a cash account card (free) to buy it, but no fuss otherwise. I recon a whole undertray can be made for £20ish. I will post a separate thread of the undertray / belly pan build when the time comes. |
Someone knows where i can get coroplast on the other side of the channel? In holland i only see expensive transparant coroplast for around 40 dollar.
I found a 4 foot square "For Sale" sign, beside some traffic lights:) Same material as House Estate Agents for sale signs!
Mike:) |
Iv'e been looking for the same thing and came across these folks.. has anybody used this companies products ?
"triple 'w' 'dot' protection 'dot' co 'dot' uk .... proplex-4mm-corrugated-plastic-sheeting i cant add the link as this is only my third post.. :-( |
polypropeen kanaalplaat zwart 1400x500x3,0mm zwart euro 6.95 A lot more expensive than the big plates in the UK. Maybe they'll give you better prices in NL when you order a few big plates and pick them up ? H2O2 seems to have found a cheap source . |
check the higher golf course's that have outings for certain causes. The place i work at has outings at least once a week and i saw a pile of chloroplast signs at least 4 ft high and they were pretty decent sized signs to. and that was just on 1 golf cart setting em up
