Math question.
600/12=50, 600/10=60.
The difference from 10 to 12 is 2, the difference from 50 to 60 is 10. 11 is 50% of the difference between 10 and 12, 55 is 50% of the difference between 50 and 60... BUT! 600/11=54.54e. Um? |
I find it helpful to visualize multiplication and division geometrically. Consider rectanges that are 10*6, 12*5, or 11*5.45 to see why your first intuition isn't correct.
Its not my intuition, and I wasnt asking a question... Its pointing out that there are inconsistencies in digit math when using percentages compared to integers.
Intuition would tell you that since 11 is 50% of the diff between 10 and 12, and the respective solutions for ten and twelve were 50 and 60, the solution for 11 should be 50% of the difference. However, average would-be mathematicians haven't accounted for the scaled increase when using the percentile as an intuitive route to check a solution. 600/11 is, in fact, 54.54e, just slightly less than 50% of the difference between the solution for 600/10 & 600/12, even though 11 is exactly 50% of the difference between 10 and 12. |
Math questions are answered here:
http://www.khanacademy.org/ Specifically on percentages: Khan Academy |
Christ, if you were to divide different numbers by the same denominator, then the function would be linear, and proportions would work. But when you divide the same numerator by different denominators the function is now rational, which is governed by its own laws. Percentiles and averages become less intuitive.
42
Odin -
CarloSW2 |
C, the answer is always "C"
Christ -
I made this plot of denominator increments of 0.1 and the result : http://ecomodder.com/forum/member-cf...math-stuff.jpg The red line is "as if" the result was linear. CarloSW2 |
That illustrates the point, Carlos. Thank you.
12/600=.02 11/600=.0183e Still not linear. Did I misunderstand? When I first noticed this, years ago, I thought it was simply because 11 is prime. So I tried this: 600/16=37.5 600/14=42.857142 (42.86) logic suggests that the answer to 15 then should be 37+2.675871= 40.178571... But it's Not...it's just 40. A difference of .178571. Thinking back, the difference was .45e, just a couple numbers ago... The closer the numerator is to the denominator, the difference gets exponentially smaller. |
0.183e is exactly halfway between 0.016e and 0.02, so it is linear.
As Piwoslaw said, changing the denominator makes the relationship 1/x. The only thing that is really logical in math is... logic. I love logic but most other math (especially thinking for ages about how it works) makes my head hurt. |
