Mazda i-ELOOP regenerative braking system using capacitors
This was interesting to see. Its similar to what a few mfgs are doing by fully powering up the alternator during braking, but they're using capacitors to be able to capture more energy. They're also bumping up the alternator output voltage to capture more energy as well (variable from 12-25V). They claim a max FE increase of 10% which is what we've seen be eliminating the alternator here on EM.
Mazda Improves Fuel-Saving Start-Stop System With Capacitors |
Daox -
Interesting, but will it work with a manual transmission (i.e. decel w/ clutch in)?
Daox -
CarloSW2 |
It would be interesting to see what kind of capacity that capacitor has in kWh, and what kind of current that alternator is pumping out at 25V.
I just saw a commercial about it and did a search here, and of course you guys have already discussed it.
My dream vehicle is an AWD station wagon with an electric drive train. I think the combination of ultracaps with batteries would allow for high energy takeup from braking, then using that same energy to help accelerate and recharge batteries. Of course, in my dreams, the recharge connector would be in the back, so I could put a small diesel generator on a hitch platform or a small trailer for longer trips. Mazda's use of capacitors (I assume Ultra) is one step closer to my dream. |
Holy crap, this looks like it's pretty close to being commercially available. Good for Mazda!
25V alternator is a little disappointing though, with field coils at 12V you should be able to get over 30V in the 2000s (engine rpm). Still, improvement over 12V I suppose. I wonder why they mention AC/DC converter. Could it be an inverter that feeds power back into the alternator (and uses it as a motor)? |
...bet Mazda is taking the "cautious" approach and only using 25V because it's essentially a multiple of the common 12VDC lead-acid battery already available...super simplistic, but VERY co$t-effective, and CHEAP.
perhaps they are using a different set/type of diodes to adjust how much voltage is being produced. alternators are pretty inefficient, maybe they've improved that as well.
By allowing the alternator to produce power at higher voltages automatically boosts the efficiency :) |
AC-voltage can be stepped UP/DOWN easily, but not so DC-voltage.
