Mazda Sky Active X! (HCCI gas engine: compression & spark ignition)
Anybody else excited to see the new Mazda sky active x implementation? Mazda predicts a 30%+ fuel economy gain over current sky active G engines and it makes more horsepower similar to a 2.5 vs a 2.0. What is really curious is that under light load condition it runs on lean compression ignition, but under high load it swaps to spark ignition. I hear similarities to a new and improved vtec-e. Thoughts?
Always beware of the term 'up to'.
It's a 30% gain only in the narrow band that HCCI will operate in. So owners won't be seeing 30% reductions at the pump. It's a bit like lean burn or cylinder deactivation. |
I thought it would resort to spark ignition only to keep it smooth while idling or at an extremely low RPM.
But if the 30% is specific to say 65mph that's perfect for highway cruising. The EPA test cycle doesn't pick up these kind of things which means manufacturers are discouraged from trying things that may actually be really effective in the real world. I have no idea if this is the case with this car but I always like to dig into the EPA raw data and look at the old standard highway cycle results. That number better shows what is possible to get if you try.
This was the same problem with Mazda's iStop. The EPA city cycle doesn't show its effects, even though real world testing has shown a 0.5 to 1 km/l difference in 8 km/l traffic.
We have to wait to see what Mazda does. I am assuming that it uses HCCI over a wider cycle than GM's older system precisely because it uses spark-controlled compression ignition. |
Just read up on the i-Stop and it sounds amazing. How they get it to do what it does, reliably and without stressing the engine, is a feat of engineering.
Idle stop is pretty much ubiquitous nowadays. Renault's is said to be good for 400,000 cycles. That's once a mile for... well you know.
Mazda's is the best system, but in practice, I've tried to beat Renault's system and can't. My Fiat's is much more of a 'first gen' system, no where near as polished, but gets the job done usually. |
Nowadays with idle-stop, regen braking and some mild degrees of electric power assist are becoming more widespread, it would not suprise me to see starter motors becoming more overbuilt to stand those operating conditions, eventually integrated with the alternator/stator/whatever type of generator for a more compact packaging.
And, as oldtamiyaphile says: It's the best system. Much smoother than the auto-stop systems the Germans use. - Similar in concept to SkyActiv X. Integrating separately clever but (relatively) simple solutions into a system that is greater than the sum of its parts. |
It likely stops the engine at or near the start of the compression stroke with just enough fuel to charge that volume under no compression. Quick hit of the starter to make sure the engine rotates the right direction, fire the spark plug, instant power stroke, suddenly doing 600rpm.
iStop? I don't know why iMac annoyed me so much, but I can't believe 2 decades later and marketing still thinks preceeding things with a lowercase "i" makes the name cool. I'm already embarrassed at having to explain this nonsense to my future children.
Anyhow, I have a 2017 Mazda CX5 on order. I'm guessing it won't have any of this cool stuff mentioned here. I know very little about the vehicle since it is company provided. |
The one issue is that you require a deep cycle battery, which costs... well... not an arm and a leg, but a few fingers and toes, at least.
Friend uses a regular battery in his car. He simply wedges the iStop button down with a piece of folded paper. No iStop, no need for deep cycle. :D |
Why is a deep cycle battery needed?
Because of the start stop function you require an AGM battery. This allows multiple starts and rapid charging in between, something a normal car battery doesn't need to do.
Especially when running cabin ventilation, lights and entertainment while the engine is stopped. |
I've got to do an infographic on that system soon. It's uttelry fantastic.
All that "content" leaves me cold. Not impressed.
Make mine a modern Model T with about that level of amenities. Guess I'll have to make my own. |
I drove a Russkie truck that might suit you. The UAZ Hunter (military Jeep)
Sliding windows. Good old dip switches for the fuel tank switchover, headlamps and running lights. No radio. Simple AC system. Only electronics are the engine management systems. Built to go way, way off-road. Dual live axles, near-vertical approach angle. Cloth roof. Diesel economy. As a bonus, rides a bit better on road than a Wrangler, to boot. |
Are they going to need exotic emission controls? |
I think if you drop the combustion temperature by a little bit it is easy to go below 100ppm (which should be able to squeak by the minimum standards on a smaller engine car). HCCI supposedly should be able to control the burn speed so that maximum temperature is lower. I am not sure exactly how this works, but my hunch is that they use a lot of hot EGR to control the charge temperature (to induce autoignition) and reduce the burn temperature, and somehow avoid knock. |
I bet they're using supercharging so they can keep using the long-tube scavenging header of the naturally aspirated SkyActiv G. But I haven't seen the engine fully dressed yet, so I could be wrong. SkyActiv X is going to be wild. And it won't be using unobtanium engine internals, stratospheric injection pressures or ridiculously fast and expensive knock detectors. |
Guys the numbers are conflicting here but look promising. Skyactiv X is targeting "27% better thermal efficiency"... Don't quote me on this but isn't their current engine around 36.5% thermal efficient. Thats a boost to 46.4% thermal efficiency which agrees with whats currently possible with ICE on the cheapest energy currently available to run a car aka 87 octane.
Imagine a 2016 Mazda 3 gets 33 mpg combined that could result in 42 mpg combined and 51 highway. I'd also assumme if they're going to these lengths to bust EV and Hybrid balls they will probably drop the cd down to at least 0.23. Seems neat in 2800 pound car. (https://pdfs.semanticscholar.org/226...3adda2e15f.pdf) (Mazda Skyactiv-3 Engine to achieve 56% thermal efficiency) Think of the hypermiling for the love of god. lol |
The only question is when will they put HCCI in the Mx5/ Miata.
As long as they run port injection as well (only way I've seen to keep the intake valves clean).
Having re-read Mazda's literature, it would appear that there is 1 direct high pressure injector per cylinder.
https://insidemazda.mazdausa.com/pre...s-information/ |
Adding back to the list it looks like Mazda isn't just targeting peak thermal efficiency by using compression ignition and lean burn, they are also using it to increase thermal efficiency to a much greater amount under higher loads where a Prius would say be less efficient than a Bmw m3 (see top gear test) unless its in its peak small operation window. So it sounds like it should hit the Miata.
https://www.forbes.com/sites/peterly.../#4872e924d7ff
The count down is getting close. I'm loving what I hear so far. We are either good guessers or they browse this forum. ;) "The SkyActiv-X is a 2.0-liter gasoline engine employs a common rail-style system from a diesel engine, a supercharger and a mild hybrid system (24V System) to create an engine that produces 178hp, generates beefy bottom-end torque, like a diesel, but spins freely to 6500 revs, like a gasoline engine." Also from a separate article: "Toyota has used a Subaru boxer engine in its GT86 coupe, and more recently, employed a BMW 6-cylinder powerplant for its reborn Supra sports car, the same engine fitted to the new Z4. And in return, Toyota has allowed its THS II hybrid system to be incorporated into models including the Mazda3 hybrid." So it looks like Toyota has really taken over when it comes to hybrid transaxles. Good to hear... At least there will be reliability. |
