Mechanical Concrete
https://www.youtube.com/watch?v=GdKbbhQWl3s
Is this is low-tech high-tech? Recycling tires is good. There is a negative cost associated, people pay you to take them. They show the stabilized gravel being top coated, but one could do a home driveway in gravel with just a reciprocating saw and back-breaking labor. |
I will have to watch the video later but if it's what I think it is then it could be a really bad idea of its done exactly right.
if you had gooey ground, putting down a layer of fabric followed by those tires filled with gravel would be great. Around here the ground is firm enough to have no benefit at driveway level usage, but soggy bottomland probably a good idea.
TLDR; close-packed cells prevent wallowing out. |
Ok I thought it was ground up tires mixed with agg. Yeah ground up tires try to ignite if all the steel belt isn't picked out when it gets wet.
This should work if they already tested it by making dirt roads that tractor trailers and dump trucks drive on. |
freebeard is beefing up the ol' driveway before taking delivery of his Acrimoto.
Can’t wait to see the Hearst Ranch entry gate erected (“on loan”, you know). Then the oilfield structural pipe railed fence to keep the bison from wandering onto the motorway as his Lordship is making a quick nip down to the coffee shop. . |
And I run a small coffee and sandwich shop here with a clientele of one. |
I'll donate some old tires to beef up your parking space. Maybe that's just the thing to boost your coffee and sandwich business.
It's name would be Fortress of Solitude.
I just rent the ground, I'm not going to put a lot of work into it. But a single row of tires up against the asphalt as a retaining wall might raise the parking space above the flood plane. Seriously, the lane turns into a pond. Up level with the carport would be nice. Maybe you don't have to cut off the bottom sidewalls. :thumbup: |
Ah, heck. I thought the reinforced driveway thing was great about guys who think everything that moves has a way to be ridden. Every beast or machine is Christmas all over again.
They reinforce MY driveway every time I leave home. Big Diesel or Little Diesel. The crushed aggregate is kept literally 20-feet away. I leave, and out rolls an ancient Mahindra tractor to set to work. I haven’t bought a vehicle yet didn’t require set of specialized tools or gear or whatever. Hell, I finally got management to repair my 30A power so I can order a cable with a NEMA-20 end for the Pete and a typical 30A connector at the other end. Run it on shore power while at home. So I still suspect that SOMEONES morning race to the coffee shop is bolstered by THE NEED for a CONSTANT flat-cambered downhill run to effect top speed onto the frontage road THUS a solid merge onto the highway. Overkill for the new vehicle expected is just right (per the video). And, may as well gussie up the premises while we’re at it. Said affectionately, every one of us here is a cartoon character. I know I wouldn’t have it any other way as I’m rolling roadblock with trailer in tow. Smile and wave back at everyone who honks or flashes headlights. Thank them, too, for letting me know I’m Number One. Etc. . |
They have tried using chopped up tires as mulch and ground cover, but I understand there are environmental issues. |
